95 R33 GTs-t, Silver, series 2 engine. 18k
Mods : Supra front mount
K&N pod ( still have standard box )
Polish catch can
New timmin belt
New water pump
R34 front strutt
New tyres front and rear
Pineapples ( fitted by BMT, most works and tune done by BMT )
Custom front pipe
Apexi N1 catback, 3 inches stainless steel Hi-Flow cat ( still have stock catback system )
R33GTR rear brace
Exeddy button clutch ( still have standard clutch, if i can find it )
Interior : A/F gauge on passenger side ( in dash )
Boost gauge on A pillar
Pro-fect B controller
RACING ECU ( no rev or speed limiter, smooth power curve, still have s2 standard ECU )
4 automatic setting and 1 manual turbo timer ( brand unknow )
Fire exstinguisher mount under driver seat
Alpine deck with 4 ways flip
JBL 6s rear and Clarion 6s front
Exterior : Stealth wing ( still have s2 standard, high wing )
Tiny scoop on top of pod ( cold air flow into pod and turbo )
Overall : Always change oil on time and only use Mobil 1, car running a bit rich still does a 13,6 with bad 60foot time on street tyres ( stock rims too ) and street trims that inclue car jack...spare tyre....ect.
Recomence by BMT to fit Apexi S-AFC to lean fuel out ( save fuel ) therfore gain more power with proper prepare and SAFC will definately ran 13 flat.
Reasone for selling? Family comitment.
Interested? pm for fone numbers, i'm locate in SE melb
https://www.sau.com.au/forums/topic/37273-slow-r33-for-sale/
im interested but the pic didn't work so if u could send me 1 that would b good thanks.
where in melb do u live cause once i have a look at the pic and its good i would like 2 come c it
also a price ?
thanks alot mate cheers
e-mail is : [email protected]
https://www.sau.com.au/forums/topic/37273-slow-r33-for-sale/#findComment-747962
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
