I found this inlet manifold adaptor to fit Rb26 inlet plenum and ITB's on the Rb25's plus they do a Rb20 version
At first I thought they did the old cut and weld option onto a rb25 inlet runners, but it is different
Then I thought they had done a cut and weld onto a rb25 greddy style inlet manifold, but no
I think they have made up a new casting with mounting plates to bolt the ITB's onto and have made a remote seperate IAC box. It does away with the rb26 injector section of the inlet.
The attached pic's are are R34 Rb25det version.
Having a close look at the adpator it looks the same a greddy style manifold around the injectors ports and mounts. The flange onto the ITB's looks to be a 1 piece casting, ie not welded onto the runners.
Also the reason I think it is not a greddy style manifold is the angle of the radiator hose connection.
It is square like a factory manifold and not at a angle like the greddy.
The main negative problems with either the Blitz style adaptor plate is the angle of the injectors and the cut and shunt to stock manifold is the different runner spacing and angles.
With this version they seem to have solved those issues, I can not see any problems or disadvantage with this design
Cost is not cheap at approx $700-750 plus post form Japan etc.
Does not include the rb26 setup, so add $300-400.
Your thoughts??
I have Neo rb25det with greddy style manifold already, but would luv ITB's with VCT
Edited by darrinspencer
I found them on Yahoo. I think it will be close to $950-1000 landed
http://www.importmonster.com.au/view?url=http://page6.auctions.yahoo.co.jp/jp/auction/f101401033&thumb=http://f6.auctions.c.yimg.jp/img321.auctions.yahoo.co.jp/users/2/4/5/6/assemble2006-thumb-1297139207470101.jpg&title=RB25 NEO6 GTR KIT
As mentioned, they do a Rb20, R33 Rb25 and R34 Neo kit.
No mention on the company who makes them
They look similar quality to the other cheap chinese greddy styles manifolds.
They only cost approx $150 wholesale price in china for example.
Might try and find the supplier/manufacture as I have a few contacts and inport some parts from china now.
I currently run the greddy style copy on my Neo with gt3076r
I am very keen to try one of these out and do back to back test.
It won't be be for at least to 6-8 weeks thuo.
I can't really see any negatives with this setup?
Anyone have any idea's??
i mean when you run the rb26 ITB's it apprently eliminates the vct.
I think that would happen when you use the full Rb26 intake with injector section and an adaptor plate as it would foul the VCT solnoid>
This kit is cast the same way, ie rad hose connection as the Rb25 manifold so it will clear the VCT. win win.
I have just email Aaron at IM to see if he can contact the seller and find out more info.
i found these on yahoo yesterday also after posting my comment.
although i could only find kits for rb20 and neo rb25
my rb25 is a s2 r33 engine.
definitely do more research into where the manifold is made, im eager to purchase asap
  • 3 months later...
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
