:cheers: Streeter - welcome to the Japan Residents Club (Gaijins R US :))
If you're in Osaka, you're not too far from Rezz and Evo_Lee.
As for work - unless you're fluent (ish) in Japanese there isn't a lot a foreigner can do in Japanese besides teach. If you're skilled in some trade, you might be able to get work for a big company that has operations abroad (i.e. outside Japan, in English speaking countries) though work like that would be difficult to come by. Just about all the Japan residents on here (myself included) work in Education - the only exception being Evo_Lee I believe. I know of several people in the Tokyo area, but again there either work for big multination corporations or the media/journalism.
Give the teaching job a bit of time - I wasn't too comfortable at first, but needs must and when all is said and done, I can think of a lot worse jobs to be doing! :)
Dave (in Yamanashi - the home of Mt. Fuji, me and many farmers :()
Thanks for the reply Dave... I must apologize I have been here for over 9 months now and have just been too busy/slack to get on these foums...
My dream is to get into some sort of exporting. I have been a mechanic for a few years and have been screwing around with cars for over 10 years so have a bit of knowledge and would like to think I could make a go of it.
Teaching was fun at the start but working for Nova is ghey... maybe I should start looking at teaching elsewhere?
:) You're not alone - most of the people I know of who worked for Nova didn't last more than a year before they got out. There are better schools/places to work - my advice would be to wait until the end of your contract and then start looking for somewhere else. They'll probably be a gazillion schools in the Osaka area - while most of them would have filled their teaching posts by now, a few might be looking for teachers. Getting into a school midway through the school year can be trickier, but it is possible. Most of the vacancies tend to be available from early March onwards.
You could try getting into the export business - there are a lot of companies working out of the Tokyo area, though not so many (that I'm aware of) based in Osaka. If you've got connections back home, setting something up shouldn't be too difficult. Again, it would probably help if you spoke some Japanese and had someone who could take care of all the paperwork on the Japanese side.
Good Luck
Mate good to see your back on-line, 9 months and in Osaka too, where you been hiding?
Replied your PM.
Ive been on Shikoku in Kochi city for the past 8 months drifting and getting hitched! lol thats right getting married in Hawaii in June. Things are moving mighty fast for me in Japan. LOL
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
