i run one with my rb25det its a lt12s however i only went the microtech because i got it given to me from a close mate who smashed his car otherwise i would have gone nistune or something but i dont have a problem with it
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5950162
Im also wondering is there something about them that will hold us back?
My new car has a microtech in it already and Im somewhat CBF to replace it..
If there was a major advantage I would do it.. Anyone care to sway me?
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951039
i agree ive got one already and cbf removing it and fitting AFM's etc
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951112
I just spoke to DVS JEZ quickly by sms, the basic outcome was to leave it and be happy.
Stuff like the link etc has more features but not really necessary stuff to get a good tune out of it.
In my case its an SR with VCT, I will put a window switch into it shortly and it will do everything I need it to..
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951125
my ltx12s is great,, for what i need it to do anyways?... and ppl make claims of bad cold starts, but mine starts up and idles fine when cold..
yeah my cold starts are fine aswell when cold will idle at around 1200 until warm enough then will idle at 950 i have no problem with cold starts etc
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951179
That's probably because the STD ecu is still there controlling the idle. They aren't the greatest of ecu's pretty sure they still batch fire even thought the should be able to run sequential inj/ign with ltx12.
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951213
Same with my 200, runs fine.. No stock ecu in place.
Just lazy on power, but I cant really blame the microtech haha.
Its actually as economic as factory too.. Eh we have our answers, nothing wrong with em for a basic setup.
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951418
i dont have standard ecu at all its just microtech liek i said its a rb25det in a vl commo so im runnign full aftermarket wiring loom no afm full map sensor and my cold starts etc are perfectly fine
Well sounds like they've pulled their finger out and worked out how to drive the extremely complicated IAC valve.
Can any of you comment on the sequential injection?
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951540
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
