Hi,
I am new to skylines and this site, I have just purchased what I thought was a factory skyline r33 with rb25det. After looking at the engine bay, I have found two plates, one is blue from japan and starts with ECR33, the other is green and is an import plate, and the vin starts with 6E91MPORT - I have been searching these forums frantically for some explanation.
The car is definitely an r33, it is a coupe, it is automatic, it does have HICAS, it does have a FMIC and i'd say a turbo by the feel and the sound and the power. but the plates are confusing.
I know the engine is RB25 and 2500 I can read, I am just not overly mechanical, and I want to know if someone can decode the VIN or someone works for nissan and can tell me the situation, and why my important plate starts with 6E91 instead of 6U9 etc all i can read is that the car was imported 1998, and it says U.S import, but I am in Australia, this is all new to me, can somebody reply or PM me asap or even email me asap! I need to know if i have an R33 GTST and the plates are meant to say RB25de regardless if its turbo or NA, or if infact I have an RB33 GTS or GTS25.
I would like any help I can get, the FMIC and the turbo look completely stock, there is no boost controller or turbo timer that I can see, but there is definitely POWER!
thanks
https://www.sau.com.au/forums/topic/373935-r33-help-turbo-or-na-issue/
  • Replies 55
Posted Images
Do you like buy the first thing you see and then find out what you've bought later?
Why do people do this?
So now you've been thrown in the deep end. What would you rather do? Learn how to swim or drown?
It's time to start learning, not expecting every one else to hand feed you. It is very easy to find out what you are after.
oohhhhhh you wouldn't want your vin Allover the web. maybe someone will steal your vin and do a ram raid!
f**k the import plate,what engine is printed on the blue plate?
Are your wheels 5 stud?
Just post a photo of your engine bay and stop being ridiculous.
the blue plate says ECR33 XXXXXX
then below it has model code
and then it says RB25DE - 2498cc
the wheels are the blue rim advan racing, not sure what stud pattern as I just got the car and wanting to find out more info.
are the pics any good? im sure it is turboed and it has FMIC, but i wanted to know for sure if it was GTST or just GTS with turbo?
Just by looking at the engine bay pics, and from what I can recall, those are NOT the standard hose clamps holding the crossover pipe to the throttle body.
You just found your answer. The blue plate says RB25DE. Its an RB25DE+T not an RB25DET. It was not factory turbo, but an NA gone turbo.
When I was in the market for a GTR, I found an R33. Everything looked mint. Colour I wanted, everything was sweet. First thing I did was look at the plate, the blue plate said it was an ECR33 and that it is an RB25DE. I walked away. What the hell is an RB26DETT doing in an R33 series 1 badged car with flared kit. People cheat and steal alot with changing engines around, putting plates on the car they didn't come on etc.
Yours would seem more true and legit though. You have an auto R33 gone turbo. I can't be certain but I can tell you 100% that they have fitted in new hose clamps which will lead me to believe the car is legit and that it was legitimately converted to turbo.
Its ugly finding things after you buy the car but what can you do, you will almost always find something. I almost bought a complete stock standard "never run past stock boost" r33 gtr until I squeezed the line and felt the boost pressure limiter thing was missing indicating the car has clearly been run past stock boost.
Shit happens really. Old cars, they have all been thrashed, boosted, driven hard etc. As long as she moves fine, you'll be sweet. Enjoy it.
not necessarily
hoseclamps dont mean shit.
whats to say that isnt an actual RB25DET engine that has been swapped in at some point.
OP:check the engine number down the bottom on the side at the back of the block below the turbo and see if the engine number matches up with the plate. if it does then its RB25DE+T. if it doesnt then its an RB25DET swap.
not necessarily
thanks, but I cant get under the engine to see, the car kit is too low, i have engine number on the rego papers all it says is RB25076XXXX - but the plates say ECR33 and RB25DE, and as i said its a coupe and automatic, im starting to believe it was a factory GTS25-S or GTS-4 and then a turbo was put on or yes an engine was put in later.. but the car went thru regency in the last 2-3yrs with this engine I know that much....
not necessarily
Well that could lead you to believe many things. Point is I have NEVER seen those style hose clamps up on the standard throttle body. Its enough for me to say someone changed them because the old ones were shit. This was in light of the badge work. You are going too far thinking of an engine swap... I think if he looks around, there may be more proof of an NA converted to turbo.
you can check the engine block number from above- may need to scratch it with sandpaper to view it.
cant have been a GTS4 unless its all wheel drive.
EDIT: oh and stop thinking it may or may not have been a GTS25T because it sure as hell wasnt to begin with. RB25DE clearly states this fact. the "T" in DET denotes factory installed turbocharger.
my current 33 (95 model) before i took the engine out had worn clamps and the rubber fitting was very worn. so its safe to say that those clamps could have just been from wear and tear. but you never know. im not saying it couldnt be turboed. anything could have happened
im going to put my bet down as it being swapped over in japan.
but we shall see.
Edited by 045HOW
but we shall see.
I am unable to find engine numbers, there is like NO room near engine, theres everything next to the engine and I dont know where to look, i know what the plates say, and the rego, i know it must be turbo it has a large FMIC under the bumper and big piping going under each end of the front bar to the FMIC, strangely though the battery is in the boot...... I JUST want to know if it was factory turbo or not? and why the vin doesnt seem to come up? is it a GTS-T if so why does the vin say RB25DE and not DET?
does anyone know, can anyone find the vin? ECR33-O16380
as has already been stated. get onto the nissan FAST thread in the general section and get someone to put your vin through the software
on the turbo side of the block down the back at the bottom there is a little flat bit with the engine number on it.
battery comes in the boot from factory in R33
IT WAS NOT FACTORY TURBO:RB25DE TELLS YOU THIS.
D=dual overhead cam
E=electronic fuel injection
T=factory installed turbocharger
if your blue engine plate doesnt have a T on the end of its DE then it came from factory as an R33 GTS25 NON-TURBO.
D=dual overhead cam
at first i thought it was factory turbo, until I had a look at the plate and it says RB25DE.. but then when I asked the people to put my VIN through fast ECRXXX they said it didnt work? and they kept saying ECR must be a turbo model, but then I have been researching to find that ECR33 could also be GTS25-S which is like the GTS but the RB25 engine, and the coupe and the auto. so I guess its safe to say my car was factory NA and was later converted to RB25DE+T but I will definitely get a full check and dyno asap to find out for sure what kind of turbo it is as you cannot see the actual inside of the turbo etc. hard to explain, but i guess thats the best i can do to say its GTS25-S
yep
but remember, it may be an engine swap and not a turbo conversion.
that may well be a standard turbo motor with standard turbo.
EDIT: also looking at that previous photo of your turbo i would say regardless of conversion or swap, it is a standard 25 turbo.
Edited by 045HOW
yep
Hey thnx, I kind of guessed it was a stock standard turbo on it, it just doesnt make much sense to buy a GTS and put a turbo motor in, or add a turbo, why not buy a stock GTST ?? and that means to me, the car is probably not worth as much as id hoped if its not a factory GTST but a GTS with a turbo? :(
hence why you don't just buy something out of stupidity and then ask the questions later.
I thoroughly inspect anything I buy.
Especially anything in this kind of industry.
But I guess you kids need to learn the hard way.
Nice attitude to make people want to stay and learn. As for why buy an n/a and convert to turbo, could be a few different reasons. Maybe couldn't afford a turbo model at the time of buying the car, and turbo'd it later on when they could. Could have got it on P's where turbo isn't legal, and converted once they were off P's. Or maybe they/a friend had the turbo gear/engine around cheaply, and they decided to just get an n/a and dump that in there.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
