  • Replies 55
Posted Images
I love how hose clamp authenticity is now how you confirm a genuine car.
Thread would be GOLD if it wasn't so annoying.
i Just started this threat for some helpful friendly advice and information, I am new to skylines and my first one, so of course i made a mistake hoping it was a genuine GTST - shit happens, at the end of the day its still a skyline r33 and still a turbo so its basically the same as a GTST, :) i am happy anyways I got a deal either way :P was off an old guy, only got 180,000ks on it, pretty neat in and out, came with turbo FMIC, SUPER ADVAN Racing Ver.2 wheels, 3inch full exhaust, all the good bits to start my project off :)
LIFE GOES ON!
Getting a DYNO soon
Yeah, as long as you're happy with the car, that's what counts. If it's not a genuine GTS25t, just have to keep in mind the gearbox might not be that strong for the turbo motor, and might want to consider a brake upgrade to GTST ones in the future, depends how you drive. Bigger brakes are always good, but if you take it easy then you should be alright, but if you push it a bit, then you'll want the upgrade.
If it's still running 4 stud wheels and smaller na brakes, it's ILLEGAL and the car can and will be defected.
You're also driving a car that cannot pull up as quickly do its a danger to you.
You really should have looked before you rushed blindly into a buy.
This.
Legalities aside, it still probably has better stopping power than your average commo on the streets, so if you're just driving sensibly there isn't an issue. You just have to adjust your braking style to compensate for the power of your brakes (ie: brake a bit earlier and be a bit more aware of your surroundings). The only danger really is if you're being a twat.
Sure, researching helps, but everyone starts the learning process somewhere, and could have done worse.
On the legal side, I can't comment about other states, but in WA, so long as the car's neat and looks pretty well stock, if you have the right attitude to a cop, they aren't going to know that it's not a factory turbo, they'll just think it's a GTST.
oh, and another thing, if you have a crash, and the insurance company decides to investigate you and finds out that the brakes were never meant for that engine, then they will completely void your insurance, and you will not have a leg to stand on.
You'll be up for your damage bills, and the other drivers damage bills.
Its kinda stupid leaving the car like that. You've got a car that goes fast but doesn't stop..
What the other guy did was illegal selling you a car like this - and whoever road worthied it could lose their license.
Edited by The Mafia
^^^ been there done that, n/a brakes are useless pulling up anything over 180rwkw... they just cant cope and get way too hot too easy... 5 stud + turbo brakes is definitely worth it .
Stagea brakes aren't any bigger than n/a R33 really, and they are a much heavier car, and come factory with the turbo engine, haven't had a problem thus far in every day driving? I don't see how power has any effect on braking, unless you're using the power to get to a higher speed than you otherwise would.
yes exactly - not like it would happen often, but when it did it was scary, the entire time (6 months) I had it like that (180rwkw and 4 stud) there was only twice.... just for instance on freeway, busy traffic, ass wipes keep trying to get in front of me, slow down, speed up, (couple of times) slow down, speed up (and give it a bit so people dont keep getting infront), brakeeee and i still pulled up but no where near as well....
Hi guys
thanks for all the info.
the car has been through regency in Adelaide and all passed legalities 2yrs ago when it came over from VIC, so in SA its all legit and completely stock.
UPDATE:
I had the car checked over by a local import workshop and they said yes the brakes are non turbo and the engine is a DET that has been put into the NA shell as it has 4 stud.
Its not safe but in no way defectable, its all standard height, standard turbo, and as a guy said cops will see it as a factory GTST.
and powerwise is not an issue, its completely standard only 5psi, and dyno showed 135rwkw, so the power is not an issue, nor the brakes at the moment.
I understand if I was going to go as far as 200+ rwkw then i would spend the money on the hubs and brakes.
there was a few other issues with rods and rubbers that need to be addressed first.
THE mechanic says 135rwkw is fine as stock, but a dyno tune and change the ecu setup and the boost to the max of 10-11psi of the stock turbo, and I could make 160-170 rwkw before needing to upgrade the turbo or engine.
THIS is my first skyline and I wanted it stock, so i could decide if i would like to work it up or just keep it reasonably stock. I dont race or drift, I drive it around the city, on various car cruises and car scenes,
** I did not buy it to race so I am not worried about huge power, maybe 200rwkw - whatever can be done without having to change the inside of the engine or the driveline too much - that is all I need **
any more info or advice on what i can do next is greatly appreciated!!!
THANKS GUYS
Dude, just saying - any smart cop will see 4 studs, and turbo, and bam, you're busted. Car will no longer be road worthy, and you'll have to find r33 front hubs and brakes.
maybe so BUT it went through rwc like 2yrs ago and hasnt been changed since, and it hasnt been defected or picked on in the whole time. but I will take your word and hope. ALSO my rims you cant see the studs without removing the circle cover over the hub. but thanks again.
I'll take it as it comes.
Wasn't trying to be smart, just saying.
Just food for thought - I've just finished wrecking my 1996 gts-t, have a full brake setup for sale. Hubs, rotors, calipers, lines, etc. only problem I you bought it is you'd have to get new wheels because it's all 5 stud.
Ok thanks,
well its all new to me, so yes I have alot to learn, and I may have got stung but I did get car abit cheaper so it will be worth it in the end, but at least i know it is a GTS with a DET engine setup put in. and hub and rotor setup id have to get back to you on, theres a few things I have to get done first with the car, and I am in SA, anyways I will get back to you, if I was going to go down the path of the 5 stud and the turbo brakes etc then I would be able to sell the wheels to pay for the brakes. anyways I will get back to you if I need. thanx
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
