Sick of having to remove your front bumper before organising a towtruck? Stuck in the sand traps at Mallala?
7 Funky Colours Available
Protects Front Lips and Bumpers
Perfect for Drift and Track Days
1500kg Rating
Includes shackle
Easy Installation
$50.00 + postage Aust wide
Short - 330mm (R32 etc)
Long - 440mm (R33/R33 GTR etc)
Extra Long - 580mm (S13/S14/S15 etc)
Custom Lengths Available!
Current I have:
Short:
Fluro Yellow (CAMS and FIA Approved!)
Bright Purple
White
Blue
Dark Green
Red (CAMS and FIA Approved!)
Fluro Green
Long:
Black
Fluro Green
Extra Long:
White
Fluro Green
Edited by BIT SUS
https://www.sau.com.au/forums/topic/374260-recovery-tow-straps/
Long and Extra long not available in purple at the moment, as per the listing above. The first photo doesn't show up the purple very well, it is actually very bright purple.
  • 4 weeks later...
  • 1 month later...
  • 4 weeks later...
how do i order one of there buddy?
Send me a PM mate.
I have about 15 of these left, Mostly Lime Green, but a few other colours
Edited by BIT SUS
  • 4 weeks later...
  • 3 weeks later...
Depends on how the towie loads it onto the tray. If you aren't using a tilt tray, then no doubt, it will push the front bar up a little. Its all about angles. Still, a fabric strap pressing against a flexible front bar is 100x better than a steel cable with a smaller pressure point.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
