Turbo Question
G3TINQ
 Share
if your going to change the turbocharger, be sure to go for a stand alone setup over a piggyback
piggybacks are usually comprimises and often can cost just as much once completed and tuned, if not very close
recommendations include
powerfc
vipec
you also need to make sure you have the following to support a larger turbocharger
fuel pump
injectors
airflow meter (if you go past 260rwkw)
clutch
ecu
tune to suit
in most cases you cant fit one without the other, ie you cant install injectors or airflow meter on stock ecu, and you cant tune the stock ecu (only remap)
I blew my standard turbo so I bolted on a aftermarket Garrett turbo and I still have a standard ECU, the car is running fine but as previously stated it's getting a boost cut, I have also got bigger injectors, fuel pump and AFM ready to go in. I'm opting for the nisstune board which is costing me $850 installed and tuned, if I had the money I would go for a stand alone setup.
Hope this helps - Trent
 Share
    • Grease the poly bushes as your first order of business. Moly grease. Spanner check everything else. Inspect LCA inner bushes.
    • It's usually associated with a muffler. Often in the middle of the muffler, sometimes at an inlet. Not removable by just slipping something out. usually needs butchery (read outright replacement of the muffler). There's absolutely nothing magic about any Jap exhaust brand. Totally generic. Totally replaceable with anything else that will do the job. I've replaced the centre muffler in mine a couple of times.
    • I've had a 9280, 9280's in stock form produce a bit of a whine when coming on unlike the 9180 so you may already like the turbo sound as it is.
    • So everytime the car is changing momentum, say you were going forward, and then you brake, itll do the creaking  and then wont happen when you brake again while still going forward. but once you put it into reverse and then you brake itll creak, but wont creak any more after while still reversing. And then again, when you go back to forward and the first time you brake, itll creak.  ( note will only happen the first time you brake when traveling a direction ). Wont happen, when youre going up speed bumps or hitting a pothole etc. Sound comes from Front left area.    I'm unsure as to what might be causing this sound so if anyone has any suggestions please. Ive got a set of R34 GTT brakes that I will be installing soon too. (and disregard the gutter rashes, from previous owner(s)... ) Otherwise, it has a shot set of Tein Coilovers, original bushings except poly on tension rods. Car has 138k kms. Video reference :
    • This is a good tip. Two things: Will a JASMA tag literally have the word "JASMA" on it? If not, what does it look like and is there a common place to find it on the exhaust? Nevermind. I found some images. Similar question for the restrictor. Is there a common place it would be located or some sort of indicator that can be seen from the outside? Do I have to drop the exhaust and look around until I stumble on it?
