Bench Press(With Leg Workout Attachment) / Standard Curlbar & Weight Plates
Up for sale are a few items i don't need anymore as i am upgrading my gear.
Celsius CX240 Weight Bench With Leg workout attachments.
-Bench workout
-Leg workout
-Adjustable Bench
-Padded grip for floors
-Both seats adjustable for bench/leg workouts.
-Padding for knee and legs when doing leg workouts.
-Safety locks for when adding/removing weights on bar.
Price: $200ono
Comments: Bought this 6 months ago at rebel sport and is pretty much still in brand new condition.
Reason For sale: Building a power rack.
Curl up Bar.
Price: $15ono
Comments: Still in good nick, not bend or damaged. ALSO comes with compression lock collars.
Reason For sale: Just put an order in on an Olympic bar.
HealthSteam Standard Weight Plates with dumbbell bar/collars
Price: $32 for 32KGS.
Comments: Bought these about a year ago, and still in brand new condition. Have no scratches/cracks. These have not been dropped on the floor.
Reason For sale: Upgrading to Olympic weights.
8x 2.5KG Weight Plates
8x 1.5KG Weight Plates
York BarBell Standard Weight Plates Set with dumbbell bar/collars
Price: $50 for 50KGS.
Comments: Have a few scratches and some surface rust from previous owner.
2x 10KG Weight Plates
4x 5KG Weight Plates
4x 2.5KG Weight Plates(one of them is a different brand hence the size difference).
PM me if interested. Preferably pickup only.
Where about in Melbourne are you located?
Are the holes just standard size?
If close by ill take the 'York BarBell Standard Weight Plates Set with dumbbell bar/collars'
Located West of Melbourne, Suburb called Albanvale.
Yeah holes are standard...
Sorry a bit far from me, but goodluck with the sale :thumbsup:
Hi mate,
I'm interested in the Curl Bar and 40kgs of plates (just the 10s and 5s). $50 pickup/meet in the city??
Yeah ill do $50 pickup. ill PM you now.
No worries, thanks :)
hey bud if the curl up bar is still available i'll grab it pm me
Since chef has first dibs, if he doesn't end up buying them ill PM you :)
what is sold, what is still for sale? you can edit the original thread and use the "strike-through" formatting to make it a bit more clear.
cheers.
  • 2 months later...
Good luck! You may wish to try the ausbb forums/nissansilvia's gym section. Or maybe prorawpowerlifting....but not sure if there is a for sale section there :)
  • 1 month later...
BUMP ON BENCHPRESS!! $160ono
cheers.
Yeah i planning on doing that though for some reason, the EDIT button has disappeared?
Ahh never thought of that, cheers... will be doing that now! :)
Edited by silbastian
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
