Does it matter if it's good or not if you already got one? It may not be the best out there, but it will make numbers like 370 flywheel hp. Been in a car with this combo. Nice torque in the midrange, pretty ordinary top end though, rally car style. Compared to factory turbo it's certainly an improvement. Boost was at 1.5 Bar.
Yes they have a 76mm 46 trim T04E compressor wheel which is a bit much for the GT28 turbine , it will work but not "spool" as well as some of the other compressor wheel options .
HKS replaced it with the GT2871R 52 trim and with their housings call it GTRS .
AFAIK they both use the same HKS turbine housing which can take any Garrett cartridge using the GT28 NS111 turbine . So , GT2860RS/"GT2530"/GT2871R 48 62 56T and the HKS "GT2535" .
A .
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
