Ok so im looking at doing a bit of work on my skyline. (r33 gts-t series 2) Looking for about 220-230 kw atw. According to my dyno sheet that i got with the car i have exactly 200kw atw. (anybody know is this is decent for a pretty much stock skyline or not?)
I want to put as little work and money into it as possible while still getting reasonable performance. My questions are as follows..
1. Should I get my turbo high flowed or buy a new one? I want it to pretty much bolt onto the stock manifold. ( If so, where do i get new turbo or get my one high flowed and plus how much $$ looking at?)
2. also i will need to change my ecu? or just get mine remapped? once again, where can i get this done, what do i use, and how much am i looking at? btw i am in perth.
3. if i change or highflow turbo, is there anything else i will need to modify for it to run properly?
my mods are as follows..
-full high flow 3" stainless steal exhaust .
-Front mount intercooler
- pod filter
-lowered suspension
- super heavy duty single plate clutch
and thats pretty much it besides boost gauge etc...
any and all help is appreciated!
Edited by fabb
https://www.sau.com.au/forums/topic/374870-looking-for-new-turbo-questions/
the problem is going from 200rwkw to 230rwkw or even 250rwkw is a $5k exercise
are you sure you aren't happy with 200rwkw?
a 200rwkw gtst if setup properly is pretty quick and should beat most cars on the street
you cant really get a turbo for 230rwkw, its usually 250rwkw
a highflow or HKS GT-RS will get you there
but then to support it you need
injectors
air flow meter
fuel pump
stand alone ecu or decent remap
so its hard to get any more rwkw without a decent outlay - ie $5k inc the turbo purchase itself
if you really really want that power go for it, but its not cheap
highflow or GT-RS is about the same result
highflow is guaranteed to mate up
GT-RS you can sell your old stocker for $100
but then you may have to play around with exhaust to make it fit
but then you call your friends you have a HKS turbo
both are "new" and no difference as far as reliablity etc
oh so 200 kw atw is pretty decent? sorry im sorta noob.. my previous r33 "felt" quicker , no idea why but defenitly wasnt 200rwkw. What is "Stock" rwkw for r33 gts-t? yeh im happy with my cars performance but would be even happier if i could get a bit more out of it. And i defenitly dnt have 5k to spare. anyway of pushing another 10rwkw? without stepping into the thousdands of dollars mark? Also u say "if u set up properly" any ideas also on how to get the most out of my currents set up?
Edited by fabb
peak rwkw doesnt make a car quick, average power does
what does your dyno chart look like and how is it tuned?
you can 200rwkw and then you can have "200rwkw"
its all in the tune
stock ECR33 is 140rwkw
the only way to push 10rwkw is to make the turbocharger work harder, or lean out the mixtures, or change your wheel size
most are not a good idea, a stock turbo at 200rwkw is pretty much on the failure level already - ie around 12psi ish
okay i just spoke to old owners, and APARENTLY they gave me the wrong dyno sheet when they sold me the car. they had 7 skylines) and ive only had my car for about 2 months. I knew it didnt feel 200rwkw... new dyno sheet says 201.5rwhp**** my bad BIG rookie mistake. but i knew there was no way it was hitting 200rwkw especially with those little mods. so now my quesiton is.. anyway to push that without having to spend thousands of dollars?
(sorry for wasting ur time on previous questions :// )
You 'should' get a power fc. I got mine with a hand controller for $1000
Then a z32 afm. I got mine second hand for $100
Then some big injectors. I got mine for $500 refurbished.
All that with a bleed valve will get you another 50 rwhp or so but it will stress your turbo a lot more.
Mine made 189 rwkw or 253 rwhp on 12 psi on the stock turbo.
Unfortunately there is no cheap way out of it like paulr33 already said.
if you'd like to maybe purchase my hiflow i might be able to work a deal out with you, mines already made 215kw and would probably make upto 230 and bit more, im looking at upgrading to a gt30,
for ECU recommendations Im actually leaning towards a vipec or an ecu that can take ethanol sensor feedback for fuel map trimming so you can have the 'ANY FUEL' choice in the future...
I have a PowerFC and its fine, but I wish I could use the ethanol sensor and just use whatever fuel is available... that is E85 or 98...
keep doing some reading OP, sounds like you have lots to learn about upgrades and costs....
hey bit off topic sorry, but where do you get those graphics on your car? and is it expensive? looks good
yeh that dsnt sound too bad of an idea but if I do purchase say ur high flow turbo what else will I need to support it besides aftermarket ECU? and how much will labour set me back?
We dont have ethanol at the pump in Perth. Still a valid point tho.
I would take a stab at him getting the graphics from the place that his signature is advertising?
To properly support the high flow from stock you would need computer, injectors, z32 afm, fuel pump, front mount (and oil and water lines?) and it wouldn't hurt to have a decent dump pipe. You already have a couple of these things I see. You cant run bigger injectors or the z32 afm without the computer but you can install the computer and make around 200 rwkw without swapping the injectors or the afm. They will be maxed out tho and for the injectors its not a good thing. My injectors hit 100 percent at 190rwkw or thereabouts
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
