So after my car was lowered (Still over 10cm off the ground) I had trouble getting my jack under the car in the front to jack it up.
I had a look and there was only 2 options, one was to get the low profile ramps but that was going to cost around $100 the other was to get someone to cut me some planks of wood into ramps.
I did not want Planks of wood in the boot of my car so I ened up with these:
http://www.ebay.com....=item2eb6a58754
Anyways I guess this may not be the solution for everyone but for the few people that may also be looking into a solution I thought I would share.
Paul.
https://www.sau.com.au/forums/topic/374924-my-solution-for-my-car-being-to-low/
  • 5 months later...
How low is your car? They've fit under all mine. Where are you jacking from?
Must be doing something wrong man!
Doesn't fit under the side of my car lol. I can't fit my iPhone4 between my front bumper and the ground :P
Fits under the diff at the back but no room to jack it up, have to drive up onto chocks.
Really? Is that your truck-spec 34 in your sig? I joke I joke :P
Doesn't look as good but it was stupid before. Lowered it for a car show and couldn't be bothered raising it up again after. It used to scrape if I went around a corner too fast confused.gif
Oh trust me, I cop it from all sides for that.
Obviously I was being sarcastic though, I'm pretty damn impressed with that clearance.
What suspension have you got under that thing?
Haha yeh all good mate, was just joking :P
I've got the BC Racing BR series coilovers on it. The front ones were maxed out before, the rear could still go another 60-70mm lower blink.gif Am much happier with the current clearance though, can actually drive it properly.
Did the install on mine at home, front's first got them pretty low, then the rears, was a little drunk by then and they got wound ALL the way down, just to see what they looked like. Looked boss but clunked and scraped on every little bump or loose piece of gravel on the road so they did eventually come up some.
But damn it did look good.
The 33's must be a lot different to the 34's then, there is no way in hell that the rears could go all the way down on my car without a lot of modification. Now that I think about it, the rears must have a lot more than 60-70mm still to go because the upper control arm assembly was coming into contact with the inner guard and wheel with at least 70mm of thread to go.
It was on 19's at the time, I'm not sure it would go all the way down on 17's and you can't wind them collar to collar, they stop winding before the thread does, I think to get them lower than that you need to shorten stroke length from the top.
Edited by arcticlink
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
