  • Replies 182
Posted Images
back seats fold down in accord :P
but I understand the mazda is more a young persons car, its very trendy these days..we cop some flac for having an old peoples car but its a dream to drive and was owned by a grandpa churchgoer before us..the stereo was disconnected due to his religous beliefs...
Had a look at the accord, the v shape of the hole between the boot and the backseat made the hole not big enough to fit Annas makeup chair through it. The only thing on our list that did fit her stuff easily was a mazda 3 so it looks like some form of Mazda 3 will end up in the garage.
haha..yeah I wasnt actually serious man...
It was looking good unti lthe v shape! The boot was plenty big, and it was parked next to the 3 so it didnt hurt to look lol
have you looked at the mondeo hatch?? diesel is great 5.7 l/100km boot is 816 litres or thereabouts. and yes resale is not the best when new but bargain for a three year old car.
I will have a look now
v shape? What sort of accord was it?
iono haonda accord euro sedan of some sort, the port between the boot and the back seats was wider at the top than at the bottom. made it a bit useless for putting big stuff through, apart from that is was a nice car.
Whats the reliability like? What ever car we get will be doing a lot of short trips around town for Annas business. Her being able to jump in it and get where she is going everytime is really important too.
If driven hard things wear but, thats normal for anything.
Very reliable. There are a few things that go wrong that are common to the car. The issues are well known and aren't hideous to fix cost or time wise.
I use mine for work and clock plenty of kms on it without trouble.
The service message is an easy reset. Just hold the button on the washer stalk as you turn on the ignition. Then press the odo reset and your done.
I'm in the market for a new car in the sub $40k bracket, and the XR5, 3MPS, GTI and the new WRX sedan were the cars I was going to check out. Any others worth having a look at? The Megane interests me but its french and a bit out of my price range. Not sure what else is out there though. Any other suggestions?
  • 3 weeks later...
Finally found our car, Mazda 3 SP23. Anna is happy, all her make up stuff fits, It has aircon and it has a radio so she says for her purposes it is already far ahead of the GTR! lol. I dont mind it as a daily either, comfy, handles well and isnt a slug.
  • 1 year later...
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
