hey everyone, looking for some help for a mate of mine
car is a series 2 s14 we have just put an rb25 into..problem is the limiter sounds strange, i mean real strange... almost completely flat like a diesel limiter and when held on limiter the car bogs down rly hard and starts to drops rpm....kk dont give me advice on how its a normal limiter and im retarded coz its not!...lol
things that have been to try and solve problem : ECU changed, sparks plugs changed, ign timing checked with light...
engine has had timing belt changed before he bought it, does this sound as though its a tooth out? even though car runs fine and pulls hard for standard turbo....
it is pretty standard with just a turbo back exhaust and front mount and boost t....and splitfires
any help is appreciated.
https://www.sau.com.au/forums/topic/374981-question-about-unusual-limiter/
no we havent... running a standard reg atm with i think a wallbro 255.. will have to check that then... fuel pump is probs ok made 320hp with the sr20 in it before.. cheers for the suggestion
Keep bashing that limiter and you will need to start your expensive conversion all over. The oil pumps in RBs are very weak and make the motor almost suicidal from stock. The reason why is because of the way it is driven off the crank, hitting the limiter will smash the pump to bits and have you nuke your whole motor in seconds not knowing you have no oil flow.
If you did this conversion for a limiter loving drift or burnout pig you really picked the wrong motor. Lucky you this website is filled with an abundance of references to just how bad a choice it was. Just search 'oil pump fail'.
As for the question, sounds like every other stock ecu RB ive smashed limiters with, in fact id be pretty confident I could find a video of my ex diesel limiter RB25.
both of u calm down lol... ino of the problems with rb's and oil... car is used for drift so obviously sees a fair bit of limiter... just after advice on how to fix this...
his old r33 gtst limiter was NOT LIKE THIS... it is not normal...
any more advice?
just thought id post this up because i was warned and its slightly amusing... clipped the limiter driving home tonight and BROKE THE OIL PUMP... haha :)...
to all the non believers u have been warned lol
really? they heaps weak hey?
i wonder why theres so many rb20/25's in drift that smash the limited all day every day without issues ;)
are they different simon? my mates old rb25 copped abused for 2 years before he sold it... like a set of tyres a week abuse... never missed a beat...
different from what? it seems to be the 26's that die before anything else.
rb's not as weak as people make them out to be.
certain parts are (like the pump, as OP just updated with lol)
Otherwise from what I've gathered, some people CAN'T break them while others do without trying....piece of string etc
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
