Start the car and see if the powersteering goes nuts.
If so, it is the powersteer solenoid on the rack. Have done this myself.
You lifted the motor out of the donor car (or your own) without unplugging the rack and it ripped the plug out.
We pulled my old engine out and the guys cut off the two knock sensors and this other plug which is highlighted in red cause they couldnt get them off.
They were able to use the two knock sensors plugs off my donor engines wiring loom but it didnt have this one.
If you know what this is, it'll solve the problem. I havent got all the wiring loom connected to test the gauges yet, still have other parts to install.
My first guess was oil pressure sender, but all my mechanic said over the phone was its located above the oil filter on the block under the inlet manifold, the above picture is what I'm guessing he's on about as its not the knock sensors.
Yeh found out it was the air regulator thats tucked up under the intake plenum.
Anyone know where you can purchase the connectors as the old ones still on my old engine block which was stripped to make a coffee table??
Thanks for the help guys...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
