Start the car and see if the powersteering goes nuts.
If so, it is the powersteer solenoid on the rack. Have done this myself.
You lifted the motor out of the donor car (or your own) without unplugging the rack and it ripped the plug out.
We pulled my old engine out and the guys cut off the two knock sensors and this other plug which is highlighted in red cause they couldnt get them off.
They were able to use the two knock sensors plugs off my donor engines wiring loom but it didnt have this one.
If you know what this is, it'll solve the problem. I havent got all the wiring loom connected to test the gauges yet, still have other parts to install.
My first guess was oil pressure sender, but all my mechanic said over the phone was its located above the oil filter on the block under the inlet manifold, the above picture is what I'm guessing he's on about as its not the knock sensors.
Yeh found out it was the air regulator thats tucked up under the intake plenum.
Anyone know where you can purchase the connectors as the old ones still on my old engine block which was stripped to make a coffee table??
Thanks for the help guys...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
