Im looking to get a carbon fibre hood for my r33 and was wondering if anyone knew if i can get them in Melbourne?? otherwise I'll have to pay freight to get it from Sydney or somewhere.....
also....can you buy genuine carbon hood?where from? or just the typical ones that the top layer is carbon but the underside is all fibreglass and reinforced plastic???
any help would be appretiated
https://www.sau.com.au/forums/topic/37516-carbon-fibre-hoods-in-melb/
I'm currently in the process of buying one as well...though a Fibreglass version.
This is the guys email address:
[email protected]
Seems to be a nice guy......latest that I've heard from him is that he's waiting for the original bonnet to come from Japan
I have had a Carbon top/ fibre glass bottom bonnet for a couple of months now got it through www.nismo.com.au The only problem I have had is with the cops, they don't care about the fibre glass type but they have told me that the true carbon bonnets dont pass ADR standards - I don't know my self but they didn't have a problem with mine once it was proved that it was a fibre glass base.
I think that there may have been some other threads about this as well.
Good luck I think they look great !!!
Guys, give Adam a PM, I'm not sure if it's finalised yet, but he has been working a number of Dry carbon fibre projects, one of them being geuine dry carbon fibre bonnets at very cheap prices, maybe a tad more than you would pay for fibreglass copies.. supahiro27
If you want, maybe tell him Simon told you about them..
the only problem with the ones from www.carmate.com or www.nismo.com.au is they only have one type for series 1.....which isn't to my likeing. So far i found a place called viva garage in Perth of all places that i sent a few pictures to of the types I'm looking for for a series 1 an they said "no problem....we can get them, just let us know when"....but the cost of the hoods are $1295 (carbon top, fibreglass under), then i guess you'd have to add freight...
so the search continues for now....but if i cant find what i want then i'll pay the extra an get it from there.
[email protected]
Did you contact this guy?????
where are you located? I want to get one for my car, are you able to custom made carbon fibre bonnets?
I am in melbourne ...I will be doing a thread on both wet and dry carbon products as soon as i get some spare time....It would be interesting for you all to see how its done,how much work goes into it and more importantly how much it actually costs.I may not be covering the moulding process but that depends on if i can find anything else that i would like to mould as i have already made the moulds and i didnt take any pics....look out for it in the future
Cheers
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
