Hi guys,
Two concerns, when I pull up to a stop I get a weird clicking/straining noise from the front of my car, I figured it's something to do with the brakes since it only happens then.
Next one, my brakes shudder at high speed when I apply them and shakes the car a bit, would this be the discs or rotors?
https://www.sau.com.au/forums/topic/375176-braking-issues/
R33 GTST mainly stock, height, rims all stock, yep has ABS.
Happens all the time when I'm braking and probably not the hot problem because it happens when the car is cold. I'm starting to think it's coming from a shock only cos I bounce tested them and a squeaking noise was coming from the front passenger side same place the noise does, it's hard to explain it sounds as if a brake pad was loose and rattling around.
I did a visual check of the discs and they look fine, could be something in the caliper maybe?
Hoping to diagnose the problem, I've been down the path of changing multiple things and having the same issue on other cars I've owned, it can be costly and annoying...
Edited by RobertoB
https://www.sau.com.au/forums/topic/375176-braking-issues/#findComment-5988110
    • It's been quite the ordeal but hey, at least you figured it out.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
