Up for sale is my R34 GT-R Engine which has done around 57,xxxkm's, and will be sold as a package.
Immaculate engine with not a problem.
Comes with HKS forged internals, HKS cams and cam gears, HKS injectors purple tops (can't remember size, but car made 350awkw+ with no headache's).
Twin Apexi AX53B60 turbo's that come with braided lines and nismo front and dump pipes and a power fc that is already tuned for this package.
The package includes pretty much everything, so as far as i know, you can install straight away. Won't need to waste your time shopping around for missing parts cause it includes everything.
I am asking $11,000 for the hole lot. I might be slightly negotiable, but it is advertised at a really good price considering the cheapest r34 GT-R engine i seen was about $6,000, and that's a stock engine with no turbo's etc.
Not interested in part out unless someone offers a good price for the turbo's alone or the power fc.
Also have R34 GT-R brembo calipers x4, brembo pads and rotors x4. So basically everything. I am asking $2,500 for this.
Contact me on 0425 717 715 if interested. Don't really check the computer much often, so to get a hold of me, your best option is calling/texting me.
Please no time wasters or low ballers.
https://www.sau.com.au/forums/topic/375358-r34-gt-r-engine-package/
Out of interest, how do you know the specs of the engine?
I was going to buy this car at the auctions, but then noticed that there was no oil cap . . .
Still doesnt seem to have an oil cap like the picture you posted above??
Neat buy if it can all be verified
I've been told Pistons, Rods, Injectors & Gaskets basically all the upgrades were done 6000kms before accident.
So basically pretty fresh.
And very cheap...
And very cheap...
Thanks mate. It is very cheap mind you im pretty much selling for the same price as a stock r34 gtr engine. So i have no idea why people would be complaining and low balling.
You definitely have the wrong car buddy. This car was owned for a year and a half. Put the HKS oil cap on my s15 and covered the hole with the rag. Just took a picture without a rag so people can see the hole engine rather then half covered. This is a for sale thread by the way not a discussions thread lol.
Engine is sold. Still have twin apexi AX53B60 turbo's, z32 air flow meters with plugs and pods, nismo front/dump pipes, brembo brakes front/rear with rotors, Apexi power fc. Don't be shy to throw offers!
Still have turbo's guys. Want to sell as a package with the front and dump pipes, will take $2,500.
2x z32 with plugs and apexi pods for $500.
Brembo Brake calipers/rotors/pads front and rear for $2,000.
BNR34 power FC no hand controller $700.
BUMP! Twin Apexi AX53B60 with all lines, nismo front and dump pipe $2,500. Very Responsive and good for 300-350AWKW depending on set up. I had 330AWKW on my R34 GTR on 19PSI
2x Z32's with apexi pods and plugs $500
Bremo brake calipers/pads/rotors $2,000.
Power FC no hand controller $700. Will throw in for free if you buy the lot.
Contact Pat 0425 717 715.
This is a good price guys, grab it while you can.
  • 3 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
