  • Replies 150
I dont think we should have any type of holden period. This just being me and not liking them at all. I think with other cars it should depend on what were doing on the cruise ie. mountain run or just normal cruising on back roads etc thus the faster cars dont get stuck behind someone who cant simply keep up.
I was planning on having a field day with this thread, but I wont.
Short and sweet IMHO –
Nothing Australia full stop. (Except aussie spec skylines)
Only a hand full of none import Nissan cars invited. Example; Supra’s Porsche’s etc.
Cars that are none Nissan (that are invite only), should ONLY be a performance import, or some form of a euro sports car.
Your $250 daily driver is not welcome, if your nice import is off the road, don’t come to a cruise.
People who are rednecks should also be not welcome IMHO. I don’t associate with rednecks in my own time, and I don’t wish to associate with them in a car club.
My $2 for now.
Ok then, Ska looks like your organising next week's cruise cause I'm certanily not comming. I would say some other stuff too but I really don't see the point. *closes SAU window* :wavey:
Boo Hoo...
God damn... Add your point of view... You might be suprised what sort of discussion it provokes... I know of quite a few active members who want you to stay...
I'm against it to be honest... I think you would be better suited to qldstreetcars or boostcruising IMHO...
Boo Hoo...
Strutto is right, add your view. This is a forum, where opinions and views are posted.
Even the name of the club makes it blatantly obvious we are a model-specific community. FFS if we organise an event as part of Skylines Australia, is it that unreasonable to expect a large majority of participants to be driving Skylines?
If someone tried to bring a Falcon to an organised meeting of a Commodore club, or an Excel to a Street Machine meetup, they would more than likely be told to go their own way (perhaps not in those words). I think the fact that we, as a community, are even discussing this shows the open-mindedness of the group as a whole.
Im an active member "i think" Phatmirage in my opinion and others that are enthusiasts should be aloud to, yes there is a point and yes maybe not on the huge skyline cruises but thursday night meets whats the problem? I have nothing but respect for Phatmirage in particular as this guy has to be able to drive to be able to keep with us on some of the runs we have done and that car surprised me, it goes awesome. Just my 2 cents i suppose wether that counts or not i dont know, but personally were performance car enthusiats and all share a common passion.
Cheers
John
Cheers
John
:P
Exactly - I think the best solution lies in not trying to make blanket rules to suit every situation (speed limits anyone?), as a few people, myself included, have mentioned a few times previously. Some cruises will be Skylines only - if it ain't a 'line, it ain't coming. Other cruises would certainly be more lenient. I suppose how we treat a particular cruise would depend on whether it's purely a social thing or whether there is a bit of showcasing the club happening too. What's the point in having a Skyline club if you don't need a Skyline for some events?
But yer, I'm stuffed, going to sleep now :P Behave kids :)
You may want to re-think that one. What about finical members once it’s up and running? They may have sold there skyline/buying another or even wish to drive another import he/she may own. I think saying to finical members “piss off” your not coming to a skyline only cruise if they wish not to take there skyline, or may not even have one for above reasons is a bit silly.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
