Hey guys, have whats left of this r32 that I parted.
The shell has had a front driver side impact. Pushed rail over and up. Strut brace was bent, so im guessing pushed tower over a bit too.
Car is complied, previously rego'd and not written off.
Shell IS NOT ROLLING, has no subframes, brakes, diff, entire drivetrian gone. Will have 4 stock struts/springs, front upper arms and front knuckles.
No front end panels, except for Passenger side guard that has very small dent up near windscreen.
Clutch setup (pedal, master and lines) gone.
Handbrake and mounting bracket gone.
Shell is straight apart from front end, good rear quarters, tail lights, bumper, boot with wing. Complete doors. Still have full glass. Windscreen cracked. Fuel tank and lines all there. Shell still has brake lines
Interior is complete apart from front seats, dash vents. Good carpet. Dash has one bubble about 40mm long just above glovebox.
Climate control, power window switches, door trims all still there. C pillar trims cracked when trying to remove.
Basically don't want to spend any more time stripping it, NOT TAKING GLASS OUT. I'm after $500 for whole car. Bring a flat bottomed trailer or flatbed and drag it away.
But for the larger things;
4 stock struts and springs, good condition $200
doors complete (trims, switches, glass, mirrors) $100 each
Rear bar $75
Rear lights $100 pair.
Boot with wing $100.
Also, I need some parts, so will consider trades/
I need a front mount for cefiro (same as r32, 33) prefer turnflo, but and generic will do.
Also chasing a rear 5 stud hub.
Pics before i stripped it, shell is still in same condition.
Nowra NSW 0400257530 or pm
https://www.sau.com.au/forums/topic/375586-r32-shell-parts/
  • 1 month later...
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
