Hey guys yes VCT is turned off it was
Dropping off at hi rpm now it has another kick
He also said that the front pipe an pod are holding it back...
Peak power is more likely to be held back by your fuel system than your front pipe and pod. VCT can be turned off mid way through, so have it on until 5000rpm to boost your torque up to that point (you're definitely missing torque out down there), then turn it off to ensure that it maintains the same high rpm power you are currently seeing.
The reason it feels like a stout kick up high is before its lacking the torque the motor could be making up until 5000rpm, the engine is designed to rely on VCT to have a good spread of torque - you're potentially missing out on ~10% of the torque you COULD be making at 4000rpm, which you'd definitely know about.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5993328
Was it fully tuned with it both engaged and disengaged? Dynoing with VCT off in areas where the engine is tuned with it on - or vice-versa, means that the tune will be off for the current state which could give a misleading indication of where the curve intersection point should be in an ideal situation.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5993425
When you say fully tuned, do you mean an individual tune either way? The comparison was done on mine with only one tune, the current one. I lost 20rwhp in the middle from having it off. It made no difference above 3900 so that's where we left it.
Also, DVS JEZ mr nissan would have worked out the vct switching point based on a car running 5 to 7 psi through a stock turbo with an entirely stock car. Its possible that when a car gets everything on it swapped over from the computer to the tailpipe that it would have a different vct switching point.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5994661
Mr nissan would have spent alot of time working out the best VTC switching point
Probably, but when we are tuning non-factory setups with non-factory ECUs we don't have the luxury of using whatever rules Nissan implemented - nor can we be assured that they are calibrated to perfectly match whatever deviation we have from what they designed in the first place. We can't even be sure that they had our best interests (ie, powah!!) at heart, I know of other manufacturers definitely making decisions on this kind of thing based partly on how "exciting" it feels (often at odds to the outright best performing), emmissions, fuel consumption as well.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5994746
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
