I have a number of R34 parts for sale:
  1. R34 3-gauge cluster - perfect condition $70
  2. R34 3-gauge surround - pretty good condition, minor wear to the R34 interior paint $70
  3. R34 Orange Front Indicators - perfect condition $30
  4. R34 Manual Gear Surround & Ashtray - as above with 3-gauge surround, some marks/wear to R34 interior paint $50
Happy to post - send me a message for me to contact postoffice and get a quote on postage.
Pictures of items:
https://www.sau.com.au/forums/topic/375861-sa-various-r34-parts/
hi, could i buy the r34 tripple gauge surround?. is it ok to post to the gold coast?.. can you do a deal on the tripple gauge as well?.. i was going to test and see if i can get it working on a r33?, do you have the loom for the back?.. thanx
gear surround is now sold.
I also have a Gates timing belt I bought earlier in the year for my car prior to it's accident. These usually sell for $100+. This is brand new, never used, original box - $70 + P&H
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
