There was a chap here selling some parts, in the picture he had an R33 bonnet which had a vent/duct fitted to the standard bonnet just above the filter location. It was NOT a flush mounted vent, it sat on the bonnet rather than moulded in. This is what I want. Does anyone know where I can get one? Most I find are mounted from under or flush mounted, but these ones that sit slightly above would be an easy DIY(no putty work, cut, seal, paint and fit).
Something like this but not CF http://www.justjap.c...518&cat=&page=1
Or if I can get one in CF, cheaper, that would be mint.
http://www.ebay.com.au/itm/Genuine-Carbon-Fibre-Fiber-NACA-Vent-Scoop-Intake-/260844260372?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cbb878c14
Is this price fair? Can anything like this be found locally?
Edited by SargeRX8
https://www.sau.com.au/forums/topic/375973-bonnet-duct/
My car is currently in the shop fixing rear-end damage - they're going to be re-spraying the entire car. I can't decide if I should take this as a sign to fit one of these ducts whilst the opportunity is there. I've googled around images for the 'real' NACA ducts on v-specs, and they seem to mount them from the top rather than the bottom (and then almost moulded into the carbon bonnet underneath from what I've seen).
I can't decide if it would look better or worse to mount from the top of the bottom - have the edge around it on top or more like Terry's old car where it was done from underneath. I suspect there would be better airflow from the top method, but I'm worried it wouldnt sit flush enough or look 'right'.
Gah!
Reference images:
The other thought I had was whether I should just replace the bonnet altogether with a GTR one (NACA duct in it..?), replace hinges, latch, upright, then try and find a bonnet mole to fit ..
.. decisions, decisions ..
Edit: And here's a link to the other thread: http://www.skylinesaustralia.com/forums/topic/359775-could-r35-air-ducts-be-used-in-later-model-skylines/
https://www.sau.com.au/forums/topic/375973-bonnet-duct/#findComment-5997862
That kind of looks nice but I also kind of don't like it. This is what I want and I want it in CF. My car is white, and anything CF on white looks minty.
I really want it where it is in the pic I attached but I can see use for both locations, at the rear to cool the turbo, at the front to feed my air box. Ahhhh decisions decisions!
Edited by SargeRX8
https://www.sau.com.au/forums/topic/375973-bonnet-duct/#findComment-5997869
  • 3 years later...
Thread dig, Has anyone else modified their bonnet to fit a vent?
I've had to cut some of my bonnet re inforcement out to fit my turbo so I was thinking I'll put something really subtle in.
That way I can get rid of some excess heat/ have cool air onto the compressor housing
https://www.sau.com.au/forums/topic/375973-bonnet-duct/#findComment-7430336
  • 4 weeks later...
I know this is a Cosmetic threat, but the mention of cooling down the turbo triggered the memory of a tech article I read once on the benefits of reducing the amount of heat lost by using wraps and blankets and such.
Interesting read: (ignore the product placement, the theory is transferable)
http://www.motoiq.com/MagazineArticles/ID/3631/PageID/8208/Nerd-O-Scope-Keeping-The-Energy-In-Turbos-Using-PTP-Turbo-Blankets.aspx
Essentially turbine heat (of the exhaust gas) equals more power, and letting that escape ain't so good.
Cosmetically, I don't mind the look of these in the front near the airbox, but to me looks kinda weird up the back near the turbo.
https://www.sau.com.au/forums/topic/375973-bonnet-duct/#findComment-7451247
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
