Is Vct Enabled
Yep it sure does. Tone wheel lines up in the same spot perfectly.
Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
