my nissan r33 ,ive changed pod k&n fillter ,i new iridum spark plugs ,boost control to 11 psi .when i go 5000-7000rpm i sometimes get a popping noise throw exhust. Pen lugs are set at 1.1. the problem when i accelerate slower its ok . but when when accelerate full throtle at arround 5000-7000rpm i get poping.
it fills like to much air & fuel is going into the engine & coses to cut out .cars got front mount intercooler & apexi exhust.
IF ANYONE CAN HELP IT WILL BE VERY HELPFULL :wacko:
Pull the plugs out and either gap them down to atleast .8mm or buy some bkr6e pre gapped at .8mm. If this doesnt fix it u will need new coil packs.
Or u can drop the boost back down to stock
new plugs iridium 1.1 all good :banana:
Buy coppers next time and gap to 0.8mm. Kristina are horribly expensive. I buy a set of copper plugs for mine for $20 and I run 18psi all day everyday. You don't need iridiums as has already been said, coppers will save you a bunch money
^ as already said before buddy, it will probably bee your ccoilpacks. Either do a refurb on them or buy some expensive splitfires. I would just do the refurb and drop the boost back until I could afford the splitfires buddy. Get a video up of it on youtube and post the link in here if your still concerned.
as already said before buddy, it will probably bee your ccoilpacks. Either do a refurb on them or buy some expensive splitfires. I would just do the refurb and drop the boost back until I could afford the splitfires buddy. Get a video up of it on youtube and post the link in here if your still concerned.<
    • Yea I could, but it is amusing how shit a stock seat and belt are
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
