hey guys. done a search and havent found the info im after. im after a 34 Ztune front bar side skirts and rear pods only. is there anywhere in melbourne that does them? besides jsai ive heard there extremely slow. and spoilers galore wont tell me who they buy it off so im not sure on the quality. will an aftermarket fibreglass bar be all rippled and wont line up?
if someone knows a good place that has quality bodykits let me know
cheers
https://www.sau.com.au/forums/topic/376165-r34-ztune-bodykit/
  • Replies 62
Ive got the rear pod nismo style from jsai.. Won it thru ebay bid.. and now im thinking of putting on the nismo side skirts too.. Where are goin to order your side skirts from? Wanna do group buy? Im keen for side skirts..
Edited by myRB25DETT
Or just for laughs, find the part number for the Nismo Z-Tune front bar, call up your local Nissan dealer and see if they can order it in for you.
They will either be thinking "WTF?!" is a Nismo Z-Tune front bar..?
Or they would list you a price and you'd be "WTF?!" I am not paying that!
:laugh:
Some Nissan products are actually good in price as I have bought a few parts from them.
That's is a lot for a front bar.
But you'd expect it, if it being a genuine Nismo Z-Tune Front Bar.
+ you have to paint it the colour to match your car.
Unless you buy copies and hope it all aligns and fits correctly, cause if it doesn't then you gotta spend the cash modifying it to fit.
Or at least find a company that makes good copies of it.
But if you can justify it, then go for it.
got quoted over 800 for a front bar in fibreglass is that way to much?
Sounds ok if it's a Nismo Z-Tune...
I am only familiar with R32 GTR Front Bars and I was told the prices go anywhere from $400 - $700 (Non Nismo, I think?)
The Average price for a Nismo R32 GTR Front Bar is around the $550 mark, 2nd hand.
Either way, $800+ for a copy Nismo Z-Tune Front Bar sounds better then $2500 genuine, when you cannot justify the genuine price.
+ You will need to paint it as well.
As long as the fitting is good then go for it.
yeh i didnt include shipping from syd to melb. im going ahead with the transaction hope fitment isnt to bad. i know it will need a bit (the main reason im doing the front bar is it sits higher than standard vspec bar so i can lower it more hehe) i might put up some pics :)
cheers
hey mate, this reply might be a bit late in coming .. but in my experience (and it has been suggested by others in the past i think) if you're going fiberglass, it may be a good idea to get the parts from the guy who will be fitting them, leaving them with the hassle of fitment, and someone to go and see if fitment problems start to show after. (in my case the sideskirts on the drivers side door werent fitted very well and has lost a fair bit of its paint from the door opening/closing - not too sure if i explained that too well)
anyway all the best with the bodykit!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
