Hey Everyone,
Just wanted to check in and see whos still around from the team Northside days?.
I've been away from a few years, lost my forum password ( but with help from Blitz recovered it), Sold the R33GTR.
Missed driving a skyline so much i've just bought a R33gtst, as well as my honda S600 convertible.
Hope everyone is doing well and looking forward to catching up with the old and new skyline owners at upcoming events.
post here and say hi :)
cheers,
akira
https://www.sau.com.au/forums/topic/376444-team-northside/
s600
@evil weevil....could you put me in touch with your old workmate if possible?.
May need help with spare parts and technical advice further along the line.
R33gtst is stock...trying to resist going down the modified path :)
Edited by akira
https://www.sau.com.au/forums/topic/376444-team-northside/#findComment-6004632
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
