I AM SELLING OR SWAPPING MY LOVED R32 SKYLINE GTST.HAD SO MUCH PLANS FOR THIS BUT PLANNING TO SAVE FOR A HOUSE.PLEASE NO LOW BALLERS OR STUPID OFFERS.IM NOT IN A RUSH TO GET RID OF THIS CAR BECUASE I LOVE IT.
REGO:FEB 2012
1.ADJUSTABLE CAM GEARS
2.GATES TIMING BELT
3.KOYORAD RADIATOR
4.STANDARD AIRRBOX WITH STAINLESS STEEL INTAKE PIPE AND COLD AIR INTAKE PIPE TO AIRBOX
5.STRUT BAR
6.YELLOW JACKET COILPACKS
7.HKS BOV RELOCATED TO FRONT BAR
8.D1 SPEC CATCH CAN
9.ALL WIRING FOR SUB AND AMP IS THERE JUST NEED A SUB AND AMP
10.T3/T4 TURBO
11.3 INCH TURBO BACK EXHAUST
12.GTR INJECTORS 444CC
13.GTR RESISTOR PACK
14.SERVICED ITH MOTUL OIL AND DRIFT OIL FILTER
15.HID'S
16.LOWERED AND KYB SHOCKS
17.TOMEI PONCAMS
18.DUAL STAGE BOOST CONTROLLER WITH SWICTH BUT SWITCH IS NOT CONNECTED
19.CLARION DVD HEAD UNIT
20.MOMO CORSE STEERING WHEEL
21.AUTO METER BOOST GAUGE
22.NISMO SHORT SHIFTER
23.NISMO GEAR KNOB
24.HAS SCRATCH AS SEEN ON PASSENGER SIDE
25.ROOF NEEDS RESPRAY
26.NISTUNE NEEDS A RE TUNE
27.DASH LIGHTS FLICKER
28.GTR REAR SWAY BAR 24MM THICK
29.FMIC
OTHER PARTS FOR SALE:
1.R34 HIGHFLOWED AND STEEL WHEEL TURBO
2.38MM TURBOSMART EXTERNAL WASTEGATE
3.STANDARD EXHAUST MANIFOLD
4.STANDARD REARSWAY BAR
5.ALLOY REAR SUBFRAME BUSHES BRAND NEW BOUGHT FROM JUST JAP
6.WALBRO 255 FUEL PUMP
7.BRAND NEW SARD FUEL PRESSURE REGULATOR
8.BRAND NEW HPI DUMP PIPE MADE IN JAPAN
THATS ALL I CAN THINK OFF AT THE TOP OF MY HEAD.
PLZ TXT MY PHONE YOUR OFFER AND QUESTIONS THANKS
post-84737-0-55139300-1315816471_thumb.jpgpost-84737-0-18652000-1315816496_thumb.jpgpost-84737-0-68887700-1315816514_thumb.jpgpost-84737-0-75292900-1315816529_thumb.jpgpost-84737-0-87378100-1315816555_thumb.jpgpost-84737-0-61960600-1315816569_thumb.jpgpost-84737-0-61960600-1315816569_thumb.jpgpost-84737-0-20931900-1315816583_thumb.jpgpost-84737-0-76403300-1315816604_thumb.jpgpost-84737-0-32259900-1315816619_thumb.jpg
https://www.sau.com.au/forums/topic/376965-for-sale-or-swap-r32-gtst/
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
