Hey guys,
So basically after scrolling through the parts classifieds and not finding what i want..... browsing yahoo Japan and becoming a woman with PMS not getting her way, I want to know if anybody knows of any local Wrecks?
Basically I want a few parts for the interior of my car, that short of searching for on yahoo Japan, i currently don't have many other avenues. Actually, reword that...I want to change the entire interior of my car. I want to change all the dash components, door trims and pillar trims from the baby poo(beige) to black.
I will paint the Pillar trims, and have carpets re trimmed, so really just needing dash and centre console. What are my best bets?
Cheers
Scott
https://www.sau.com.au/forums/topic/377045-local-m35-wrecks/
  • Replies 46
I have seen a couple of full cars around that were destined to be wrecked/parted out - Im pretty sure they wanted to do halfcuts with the engine before stripping the cars though.
Id have a look for sellers on Ebay that have random interior components, and then touch base with them to see if they have the rest of the car to part out.
Haha thanks for that, But I will be getting my current seats re-trimmed in a leather so no need to worry. That was my other option, touching base with those that have a few parts advertised.
Feel free to advise of any that come up in this topic. Cheers lads.
if anybody does find a wreck let me know. ill be keen on the Motor..
guy that bought my stagea has already blown it up lol
If you want a halfcut, Nisswreck has been wanting to offload one for ages! Should make interior parts avaliable too! I know they can be a pain to deal with though :/
and WTF did he do!
hes a limiter junky.
he wouldve sat on the limiter, and im pretty sure our limiters are fuel cuts.
rich lean rich lean rich lean BANG.
los compression to both centre cylinders on each chamber.
If nisswreck have a half cut ill give them a call.
http://www.nissansilvia.com/forums/index.php?showtopic=498369
They should have at least 1, possibly 2. Let us know how you go, I wanted a couple of random interior panels from them months ago but they didnt want to strip the interior as they were still driving the thing around for deliveries :rolleyes:
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
