i've removed the intake pipes and front turbo coolant lines and one oil line but i think the other oil line is under the exhaust manifold. can't get the bottom bolts off the exhaust manifold.
i've moved my power steering pump and still no luck. can't get a socket on them! getting pissed off!
i also can't crack any of my dump pipe nuts. i have a 14 mm socket on it and 13 is too small and 9/16 i think it is is identical to 14 mm. i've slipped around one of the nuts with the 14 and i've tried the blow torch and spraying lubricant all over it.
second year apprentice mechanic and struggling big time. any one that's done this before that feels like sharing tips or a hand would be so much help. i'm going insane trying to get on those bottom bolts on the manifold.
0431398657 is my number. i live in west beach sa and would be back on the job again at around 4 if anyone is free! at the movies and then pub until then. cheers
https://www.sau.com.au/forums/topic/377505-r32-gtr-turbo-removal/
There is a set of oil water lines that stay attached to the turbos, so you just undo the ones that are easier to reach, no need to undo the inside turbo water line or the ones on the block etc. The dump pipes come out with the turbos, so dont remove them, just undo the two bolts on the bottom of the dumps that attach to the exhaust.
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
