Hey Guys.
Ive noticed a few people rated the N/A R34's as a shit car. They reckon they have nothing against the Aussie 'falcon or commodore'.
At the moment, i own a R34 N/A 4 door, with the only really power mod being the Exhaust with the following:
- Hi Tech Extractors
- Venom 200cpsi High Flow Cat
- Lukey Performance Exhaust
My mate has extractors on his 2003 XR6, and i ended up beating him by a fair car length on the legal quarter mile, i got the lead at the start because the XR6 is a bit heavier.
Then after the start, we were pretty much going the same speed the whole way, so then the end result was me beating him by a good car length.
On corners he has to slow down a terrible amount, when i can turn them pretty smoothly at higher speeds.
Although i never thrash my car ever, this was merely for testing against the XR6.
WHAT DO YOU GUYS RECKON ABOUT XR6'S VS R34'S?
Edited by R34 0125GT
https://www.sau.com.au/forums/topic/377549-na-skyline-r34-vs-na-xr6/
  • Replies 41
was it auto vs auto, or manual vs auto, or manual vs auto? that will alter the outcome. but just because you beat him on one run doesn't mean shit. when i took my magna to the drags i beat a r33 GTS-t in one run. as for how hard he can push through corners, a lot of that comes down to the confidence of the driver.
100% agreed. I went on an SAU cruise not long ago when I had my N/A R33, it was damp on the ground and through the Dandenong ranges I was going quicker than most of the other cars through the corners and I had stock EVERYTHING, keep in mind every other car was turbo or a GTR. Maybe it was because I knew the roads, maybe they had too much power and being damp didn't want to risk putting it to the ground. Didn't really prove anything out of that night at all.
People rate them as a shit car because people like you post up threads like this.
I dont know what that has to do with the car being shit powerwise?
i have hardly saw threads on 4 door skylines, your brother being one of them with his old N/A 25gt, i know him.
people rate them as slow cars compared to commodores and xr6's, when they can at least go the same.
yeah that is true, i was just pointing out what we done.
both 5 speeds. we had another run after that and the same result. to prove more we swapped cars and pretty much the same result.
it wasnt to prove historical stuff, its just r34's are proposed as having a low power rating, when the NEO engine that goes in them is more powerful than an average rb25 in 33's.
although the wieght is a factor,
TBH I did find this somewhat interesting. It would be better if you had some time sheets to compare.
The other thing is that commodore/falcon ratios are much taller and such even though you may be on top of him over short distances you'll probably find the falcon has a much better top speed.
although the weight is a factor,
I don't really care much what car a person has, whether it be a Corolla or a Corvette.
If he's keen to take care of it, services it, & respects his car's limitations as well as his own, he has the makings of an enthusiast.
One thing you've learned is the influence of the weight factor (speaking nothing yet about brakes and suspension).
In 5 years time, look back over this thread you've started and relay to us what else you've learned by 2016, and by then we'll all know if you are an enthusiast.
And one more thing: I'm sure your learning curve will be steeper as you join up and come to various events!
well that says a bit. the manual falcons and commodores are pretty hard to get off the line cleanly because of the torque (wheelspin easily) and the tall ratios (easy to bog it down if you don't fry the tyres). the v8 versions are even harder to get off the line cleanly. first gear on them is basically only really usable for parking.
out of curiousity, what sort of times were you and your mate running?
Or maybe it's becuase no-one else was racing, because it was a CRUISE on PUBLIC ROADS..... Oh, and cool Stary Bra... Is this why we keep the door locked on the NA section?
Sorry bra didn't know it was illegal to do 80kmh through a corner rated at 70kmh within an 80kmh zone.
Oh no!! >_<
If that is your version of superior handling please don't get in the way of my jacked up 2.5 tonne Patrol. It would be sad to see you driven over.
At least you are obeying the speed laws.
Oh no!! >_<
What are you even talking about?? When did I ever mention superior handling? In fact what I was talking about was that I had more courage to push it in the wet through corners than SOME (not all) drivers and it doesn't count for your car being better than anything else based on your courage alone. What part of stock as a rock NA didn't you understand lol, their verging on boats even with aftermarket suspension.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
