  • Replies 128
Who was the guy who had to bail early because of motion sickness ? SimWorld have been very genourous and reimbursed you for the night, seeing as you barely got 5mins of game play. Just PM me your details and I'll transfer you some $$$.
ahhh that was me :whistling:
seriously i didnt realise anyone left early. were they in the first or 2nd group. thats good of them :thumbsup:
Yeah, young guy with blonde hair (Steve maybe ?), gets bad motion sickness so had to leave.
The guys at SimWorld are cool, gave us extra time too :worship:
I was the one in the black r34 who left early, my stomach couldn't handle the movement, even with the hydraulics turned off. Just to give you a comparison about how bad my motion sickness is, I threw up snorkling at Rottnest, and I can give you the tip, vomiting in the ocean is not pleasant.
My mate stayed, said he raced like shit, sorry I couldn't have stayed for longer, but 10 mins of racing made me feel seedy for 45 minutes, and the food made me feel worse. Not the end of the world though. Was good meeting you all.
sorry mate but thats some piss poor luck you have. If i remember right you said the only time you dont get it is when you are drive other wise any motion and you are gone for.
Hi Fella's,
Great to hear you all enjoyed the evening. We enjoy having you guys there not only as a business but as a great bunch of people having a lot of fun.
We've now got the Rally and Sprintcars up and running so the next thing we'll focus on is Jap cars and drift cars.
All the best from all of the crew at SimWorld.
Tom Kennedy
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
