a 2.5L V35 radiator will fit perfectly.
a 3.5L V35 one will fit, with some slight cutting.
dont bother looking for a new one the same, it will eventually fail again.
either get a radiator shop to make up alloy tanks, or find an aftermarket one for the above models.
no, a Z33 radiator will not fit without moving the radiator cap location.
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6025863
thanks mate ill try to chase one up
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6025884
If you're looking at chucking it let me know and I'll store it for you. Be easier to get one made from a spare than from the one in the car...
Well that's what I was thinking. If someone has a slow leaking o-ring like mine was, they can repair this one and swap it out in a day rather than pulling it out, having it fixed, and then putting it back in.
If the process continues, it can be a community radiator of sorts.
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6026575
hi guys the temp went up on the m35 today and i found a crack in the radiator,anybody know the part number or one that fits?I'm in Melbourne and i need one fast!
My mate is having Race Radiators make one up for his V35 at the moment using my OEM radiator as the template with a PWR trans cooler included.
I am sure they would be prepared to make up another one so the timing could be good.
Let me know if you want one.
Edited by iamhe77
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6026724
sounds good,do you know how much that would cost? the guy im using can get a new stock one for $880 from Nissan so all up it will cost about $1300 :rant:
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6027375
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
