Hi guys
Seems im experiencing the same issue as a few of the US guys have been reporting, where im getting a metallic clicking noise when steering is on full lock
Its an intermittent sound, pretty much like this
http://www.youtube.c...h?v=wDLl4RCKHkw
My thoughts are either CV joint, wheel bearing, metal difference bw wheel backing and disc hub or possibly there's some truth in the front brake pad movement theory due to the missing upper pad clip
I did some poking around, and as per my vid you can hear the movement in the brake pad on my drivers side when i push the top of the pad toward the caliper - this upper area has no clip. The lower area has the clip and pad is locked in tight. Opposite side has no pad movement on upper or lower and isnt making any noise on full lock
Anyone had this issue?
Edited by domino_z
https://www.sau.com.au/forums/topic/378123-clicking-sound-on-full-lock/
I've had the clicking on and off for two years. Sometimes slight sometimes really loud. It got real bad recently, so i took the wheels off and put them back on, the clicking immediately went away. Then it got bad again so i torqued up the wheelnuts some more - it then went away again. It hasn't come back since (a few weeks now). But i am sure it will come back.
It really has me stuffed.
I've read about all the theories, i don't think anyone knows for sure what the cause is?
Lot's of people think they know because they..
1) take the wheels off then
2) make a change then
3) put wheel back on...
with noise gone.
People naturally assume whatever happened at step 2 (above) fixed it!
However, i have done just steps 1 and 3 and the noise is gone (plenty of times).
I think it's related to wheelnut torque, but have NFI why.
agree with Duncan.
the local nissan guys just take off wheels, apply a lube on the hub and and fit them back on to troque spec
This fixed mine when I had it twice but as Duncan said it will come and go. I only ever really noticed mine in carparks where the sound echoed and amplified.
Yeh mine comes and goes too, though now it's at it's loudest by far after putting my stock wheels back on
I've ordered the extra pad clips on the recommendation of Nissan who say that is their fix for this noise, so I'll see if that helps
Im also now getting the clicking noise on both front wheels and natch both front pads have the same movement as in my vid
i really think it's the brake pad moving then snapping back into place, i can't fathom this type of sound being made by the hub and wheel
If I suddenly stop just after the clicking noise, the pads are locked in tight. Also sometimes I can hear the click that split second after I've come to a complete stop
Edited by domino_z
bump
dealer fix was to remove discs and remove surface rust from the rub and regrease
clicking noise reduced by about 50% all last week
did some spirited driving on weekend and it's back with a vengeance now. So I don't think it has anything to do with the rust, it's just a major design flaw
I'm thinking about replacing the two front hubs, they aren't too expensive out of US (around 600 shipped) and I can do the swap myself to save on the labour
Edited by domino_z
We have plenty of R35 GTRs coming in with this noise as well. What we normally do is remove the wheels, remove rotors, sand down the rusts on the hub and applied lube between the hub and rotor hat. Another thing to note is the SPLINES ON THE DRIVESHAFTS AND HUB also need to be lubricated. Everytime we get a GTR coming in with clicking noise, we also lubricate the driveshaft splines as well and it seems to fix the problem. Driveshaft nuts can loosen a bit over time enough to cause this noise so obviously it needs to be retorqued when driveshafts are removed which is also why Nissan updated us to check and retorque driveshaft nuts everytime it comes in for a service since the MY11 GTRs were released as this is also what they've found that needs checking when testing the MY11 GTR on the Nurburgring. Driveshaft nuts are 225NM incase you want to know.
Also guys, its not just R35 GTRs but even Muranos, X-Trails, 350Z, 370Z and Maximas are doing it as well: full lock, on acceleration sometimes.
Be sure that after washing your car that you take it for a drive and get the brakes to warm up so that water can be dispersed from them. If you leave them standing after they've been washed, it will rust between the rotor hat and hub and cause the noise to come back earlier than you may expect. Nissan stated this on the owner's manual too.
Edited by R33_NICK
thanks for the explanation Nick
to throw a spanner in the works here, ive put my 21" aftermarket wheels back on my car and the sound has gone 100%
i'll update this thread if/when it comes back
no worries let us know how you go. sometimes the noise goes away when just tightening the wheel nuts or even the driveshaft nuts as well as when tightening it pulls the rotor tighter against the hub or in driveshafts case further into the splines which should eliminate movement tho that said the noise did come back after awhile which is why we lubricated both the driveshaft and hub splines and hub surface everytime we hear it clicking. and out of a lot we did. only a handful had the noise came back but mainly because they havent been driven after washed.
I believe it's because the way the original wheel and the disk match up. From factory they sit perfectly and needs to be put back exactly the same. If you look at your studs, they will have one marked as reference if removed for the first time at Nissan.
Edited by N/A®
Exactly. We have to mark the wheel position before we take it off so that it goes back on the same way. Nissan told us this when we were sent for training. Tip: make your on marks on the stud thats in the same position as the valve on the rim, cant go wrong.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
