Item 1:
Kakimoto Regu 06 (suit r32 gtst / gtr) would fit S13 too.
3" SS dump pipe w. flex joint
Highflow Catco Cat
Price: $600 package, posted within Australia. !!!!
Condition: Very good, apart from usual dings / scratches (see pics), comes heat wrapped in sections.
More info:
The Kakimoto Regu 06&R cat back exhaust system is designed for improved street response whilst keeping within the JASMA 92db noise limitation for street use.
  • Designed for minimum bends for optimal exhaust flow
  • Stainless Steel construction
  • Titanium like tip look using special coating
  • Improved vehicle sound but not excessively noisy.
Pictures: Exhaust has been in storage, excuse the dust/dirt.
Item 2: UAS style (possibly Silkroad) R32 gtst/gtr upper camber arms
Price: $180.00 + post (estimated >/=$20.00)
Condition: Good, were modified for longer LCA, can revert to standard by cutting washer slot (see pic)
More info:
They are for sure the best type out there, no play, reliable and last forever.
Pictures:
Item 3: R33 / Rb25 Xmember
Price: $50 + post (estimated >/=$20)
Condition: Good, can relocate rack mounts 20mm forwards for extra $120.00
More info:
Stock standard Issue
Pictures:
Item 4: Custom made SS lobster back intake w. Apexi pod and silicone joiners
Price: $100.00 + post (estimated $15+)
Condition: Good
More info:
mmmm lobster back
Pictures:
Item 5: Rb25 Power steering pump w. bracket and custom reservoir
Price: $80.00 + post (estimated $15)
Condition: Good, pump works fine, cleans up engine bay allot
More info:
Stock standard RB25 PS pump
Pictures:
Item 6: R33 Clutch Master / Slave w. Braided Line
Price: $180.00 + post (estimated $15.00)
Condition: Great
More info:
$100.00 worth of braided line
Pictures:
Item 7: R32 Rear Lower Quarter trims
Price: $80.00 + post (>$20.00)
Condition: Great
More info:
In storage so excuse dirt / dust
Pictures:
https://www.sau.com.au/forums/topic/378780-kakimoto-rb25-r32-33-gtstgtr/
hey has your cat got the stock flanges for a 34???? i think there the same part for the two models
will you seperate it?
also will your pod fit on a 34 gtt??
Hi mate, quick Q; have you got the hose lines on the PS pump blocked off? I'm looking at replacing mine, but not sure when I'd get around to putting it in... had a bad experience before with a aircon compressor that had been left open (no tape on the fluid ports etc) and had seized.
If it's all good to go then I'll take it orright :P
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
