hi all thort id put my mates car up that were building,is r30 4 door originally L20turbo manual,its taken 4 moths to get it from stock to were it is now,should be completed in 3 or so weeks,
,black top sr20
tomie rocker stopper
jjr large sump
pwr oil cooler,custom oil lines
600x300 intercoller,custom mounted in engine bay for response and battle proof
53mm alloy radiator,
high mount steam pipe manifold
garret gt2871
custom intake,custom dump,custom oil and water lines
all heater hoses,cold start,anything that can leak and cause dramas removed
3inch stainless exhaust
custom tailshaft
s13 engine cross member
was steering box,but changed to r33 steering rack,r31 steering colum custom mounted,custom power steering lines
s13 fornt hubs,nismo lower control arms,
r32 front brakes and sloted rotors
s13 coilovers
exedy heavy duty clutch
s13 gearbox custom gearbox crossmember
r200 longnose lsd
bosch 044
550cc injectors,malpasi fuel pressure reg
front faceing plenium
ford eb thermo fans
cars been completely rewired from scratch,with bare bare minimum, custom switch board mounted in center, battery behind passenger seat
auto meter gauges
velo drivers seat copy reacaro passenger seat
saas 5 point harness
hydrolic hand brake
r33 master cylinder custom brake lines
all sound deading removed,resprayed in wheel silver,
z32 afm and going with a nisstune ecu,
engine dampner
custom catch to drain back in to standard oil return
thats about it,its be design for everything to be easily and quickly fixable,motor was mounted as far and as low as posible but still able to get the gearbox bolts from the top,everything inside engine bay to allow for tapping,hopefully it going to be a good reliable weapon,
will post more pics up soon and as we get more
https://www.sau.com.au/forums/topic/378867-r30-skyline-sr20-drift-weapon/
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
fn mad! go the r30! with the sr in there itdl handle on rails! im running similar set up in my dr30, r32 xmember with 33 rack, got ne more pics/info on the rack conversion? i just want to c how u guys fitted up the crossmember.
love ur work btw
Edited by ydr030
  • 2 months later...
  • 1 month later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
