  • Replies 105
Posted Images
Yeah it looks the good, my only concern is the cut back turbine wheel compared to the 83-75, will have to try and find back to back results to see whether the extra power will overrule the extra lag lol.
Im after a mid 10 1/4 in a 3800lb Soarer...so Ill be needing 400+
Rekon a 83-75 will do that on E85? might need 35psi...but Im ok with that lol
Edit - Im basing this off Guilt-toys 380rwkw r33 which went 10.8 at 130something, my car is a bit heavier, but is auto, so by my rekoning 380-400 should get me where I want to be.
More is always a bonus though lol.
Not looking forward to getting the quotes on having the trans done to cope lol
geoff at full race recommended the 83/75 to me,..
I too am after approx 400rwkw though im doin it on 98
my set up included a built engine, mild cams, cam gears, 800cc injectors, large aftermarket cooler..still using 2.6L
im assuming u would be able to get 400rwkw on E85
well if Geoff says its a go, then I'd be oblidged to believe him.
What rear housing are you using? split .91?
1JZ's tend to need a bit more boost than RB's to make the same power when using the same turbo....having smaller ports does that.
400kw on E85 should be easily doable with a S300SX 83/75, even through an auto imho. If you're not shy on boost and setup on E85, then depending on the dyno I'd say well more than 400kw should be doable.
If you're "only" going for cracking tens with an auto Soarer and willing to go 30+psi on E85, I'd lean towards the S300SX... once you start going larger building boost against the trans might start becoming a challenge, unless you are going to use NOS.
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
