Melb Auto Salon '04 - PICS Only Thread. **OPEN**
Hey all,
Finally got around to scanning (ah, the joys of film!) some of my photos and here's a few favourites. Heaps more to come.
As usual, high res versions will be here:
http://www.skylinesaustralia.com/photopost...all&ppuser=2652
-Greg.
  • Replies 73
Coz its black, and it was in low light. Hence shutter has to remain longer to get a proper pic of your car or it will come out too dark. If shutter is open and you even twitch your finger while holing a cam you'll get a blurry pic (hence the need for a tripod). Seeing as only greg had one and a decent camera, I'd expect him to have a good one of yours.
I didn't use a tripod for any shots, they were all handheld. I was using a slow, rear-curtain flash which exposes the picture for the ambient light and flashes the subject (at around 1/840th second) keeping the subject clear.
That and the camera weighs a few kilos so hand-held shake is lot less noticable.
    • I refer you to this thread on PF, by someone who knows what he's doing. Paints a good picture of the humble AD09.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
