Volk racing Rays F-Zero Challenge forged rims.
Sizes are:
18 X 10.0 +48
18 X 9.0 +45
Comes with 255/40/r18 and 235/40/r18 Federal 595 RS-R tyres. Tyres are very new, have only done a about 1,500km on them.
Unfortunately there are a fair few scratches on these wheels. Nothing a powder coat couldnt fix though. Structurely they are fine.
$1300 ONO. (I recently paid 950 for the tyres alone and they're nearly new, so you're basically getting some volks for 350 bucks!)
(Photos of these in this thread: http://www.skylinesaustralia.com/forums/topic/370180-fs-volk-rays-f-zero-challenge-rims/page__p__5903534__fromsearch__1#entry5903534 )
R33 GTS-S Springs. I have a feeling they're not stock height ones.. might be a little stiffer than normal too. They were already on my car when i bought it. The uncompressed
heights are; Fronts - 330mm, Rears - 350mm. (Or the other way around..)
$100.
Bosch 040 High Capasity Fuel Pump.
Brand new, still in plastic bag and box. I paid $199 for this on JustJap.com and never used it.
$150.
ProjectMU HC+ Racing pads for R33 GTS-T calipers.
These are second hand, although have only been on a car for about 1,500kms. A few km of which was a deca. Still like new. Apparently just the fronts price at $350 new.. A full
set of fronts of rears which are only barely used for sale.
$300.
Aftermarket front and rear swaybars for a R33 GTS-T.
Not exactly sure what brand they are. There's a sticker on them that says ARC. Didnt think ARC made swaybars... They are deep purple in colour if that helps.. Anyway, Rear
swaybar is adjustable, Front is not. Comes with links and rear bushes, bushes for the front will need to be sourced as this swaybar is a fair size thicker than the standard
swaybars.
$300.
3" Stainless steel Blitz NurSpec cat-back exhaust for R33 GTS-T.
It's looking a little scratched and discoloured now, still works fine tho. It's very loud though just a warning.
$350.
3" Stainless Steel front pipe for R33 GTS-T.
Was supposed to go on along with an Invidia cat back exhaust i had which i didnt end up using. In good condition.
$100.
Brand-less De-Cat pipe for R33 GTS-T.
$50.
(If you want to pick all of the above exhaust pieces at the same time i can do a bit of a discount.)
Nardi Torino Steering Wheel.
$100.
R34 GTT factory intake pipe.
$40.
Modified R33 GTS-T intake pipe.
Has the middle cut out and a 3" metal pipe in it so as to stop it sucking shut under high suction.
FREE!
Apexi Pod Filter.
It's a little bent, nothing too distic though, highly doubtful has affected the performance of it.
$40.
Blitz mesh Pod Filter.
Unless it's a copy, JustJap has them for a whopping $395! (what the...)
Yours for $40!
Exhaust Shop made 3" rear muffler for R33 GTS-T
$50.
Crappy rear muffler for R33 GTS-T that silences the bollucks out of a 3" system.
FREE!
Factory R33 GTST front and Dump pipe.
FREE!
I think that's pretty much it.. I will be constantly updating the thread for anything i've missed/price changes. I'm open for offers as well.
Names Andy, i live in the eastern 'burbs of melbourne. Number is 0434145894 if you have any questions. I would highly prefer pick up as i'm a bit too busy to be sourcing
bubble wrap and boxes in my spare time but will sort something out if need be.
Photos will be up in the fullness of time. If you'd like some photos now just send me a txt and i'll MMS you something.
Happy shopping!
https://www.sau.com.au/forums/topic/379109-r33-garage-cleanout/
The Decat has iodized a bit but I can always give it a scrub for you. No cracks or holes tho. Came with a 33 gtst xaust system I bought so in theory should bolt straight up. I'll have a better look when I finish work.
Also I'm bot splitting the wheels sorry
Cheers mate let me know
Well, the flange angles don't quite match up to cat on my car at the moment.. altho if i peice together the other exhaust peices i have it seems to match, i might just have a weird dump/front pipe i'm not sure.. either way you can come and have a look at it in person if you like..
Updated price list:
(See above for details. Parts not in this list that are in the above list are sold, obviously..)
R33 GTS-S Springs.
$80.
$250.
$250.
$300.
$80.
$40.
$25.
Apexi Pod Filter.
$35.
$30.
FREE!
FREE!
FREE!
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
