The power steering belt on my 1992 R32 GTS-T is becoming intolerably noisy, finally got around to having a crack at swapping it but not having any luck.
I've printed an R32 engine manual which showed me where the tensioning bolt is but turning the bolt a long way in either direction does not seem to effect the tension on the belt.
Has anyone else had this problem? Anyone know for sure which way the tensioning bolt should be turned to release the tension?
If I were to cut the belt would it be possible to soak the new one in hot water so I can stretch it onto the pulleys (similar to the trick people use with fuel hose) or would this damage the belt?
Any tips with pics if needed would be appreciated.
Cheers,
Luke
https://www.sau.com.au/forums/topic/379306-r32-power-steering-belt-woes/
I undid two bolts behind the pulley but apparently one was incorrect as I then snapped the tensioning bolt, all fixed now though, figured out what all the bolts actually do and replaced the tensioner.
For future reference the two bolts which need to be loosened in conjunction with the tension bolt are:
One bolt in top left of pump (as you stand at front of car looking into engine bay) this allows the pump to pivot relative to the engine block.
One bolt about half way along the thread of the tensioning bolt (and just above it) which allows the tension bolt to pivot.
Both of these are partially obscured by the pulley itself.
  • 1 month later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
