My plans have changed, so I have for sale my eManage Ultimate and universal harness.
I bought it second hand and never fitted it. Im told it has a RB25 map on it at the moment, and the universal harness looks new.
Looking for $400, happy to post.
https://www.sau.com.au/forums/topic/379450-sa-greddy-emanage-ultimate/
Yeah HKS F-con. Love a Nismo, won't need it with an F-con. Don't need a Nismo with the brake wire cut either :whistling:
Costs heaps more, but I'm slowly accumulating parts. Shouldn't take too long.
Emanage is the easier solution, as its proven and cheaper. Easier to find a tuner too.
No, closest to Brisbane is Brisbane, those guys that built the HKS GTR for world time attack.
So who wants Emanage + harmess. Ready to go!
will it fit a daihatsu??
I may have a small turbo kit in mind a need some engine managementthumbsup.gif
Nice one Ryan. That's what I'd like to do too - might need a road trip to a tuner to make it happen though.
Agreed that this emanage is going for a good price, I'm sure someone will snap it up shortly..
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
