Hi guys
In the process of building my 1st rb26 i am a little bit distressed as i have not enough knowledge on this part of the build so i come here for some to shed some light thanks :D
1st question, decided to stick with Tomei type B poncams 9.15mm lift cams
on inspection of my lifters noticed they were fairly bad as they have heeps of gashes in them from the shitty camshafts, price of tomei lifters are $500 not inc freight OEM are like $58 for one!
The TOMEI Solid Valve Lifters RB26DETT are recommended to be used when upgrading the lift of the cams to over 10.25mm. The items are composed of chro-moly steel, cold forged to be stronger and light weight (32g).
that is the description of the Solid lifters from TOMEI notice how they say recommended to be used with cams over 10.25mm.... can i buy them still ? and use with 9.15mm cams?
2nd question is why are they called solid lifters? are the oem ones not solid ? they look pretty solid to me lol explain this please?
Cheers guys!
https://www.sau.com.au/forums/topic/379457-valvetrain-talk/
Both OEM and any other lifters for RB26 are solid. The RB26 description for the Tomei lifters is probably just a cut'n'paste of the description for their other RB engine lifters (other RBs use hydraulic lifters) - hence the silly language involved. And this would also be why the confusing language about what lift to start using solid lifters at - other RBs need to be converted to solids once you start using high enough lift cams.
In your case, using the Tomei lifters with 9.15mm cams will be no problem.
Edited by GTSBoy
https://www.sau.com.au/forums/topic/379457-valvetrain-talk/#findComment-6051079
one of the only reasons im sticking to these cams are that any bigger lift eg 10.xx mm cams would be so big that apparently the head needs to be cut a bit to fit them using a dremmel tool or something so i shit myself n thought ok maby i just stick under the 10mm lift lol
any1 able to confirm zebra?
https://www.sau.com.au/forums/topic/379457-valvetrain-talk/#findComment-6051170
Not if they are designed for small base circle cams.
Might be worth double checking
But are any of the Tomei cams like that? Aren't small base circles the territory of regrinds? If the big lift Tomeis generally need the edges of the bucket bores to be cut, then they're not likely to be on a small base circle.
Worth checking nonetheless, just to make sure, coz I could be quite wrong.
https://www.sau.com.au/forums/topic/379457-valvetrain-talk/#findComment-6051177
Just had a look, Unless you have already taken the shims out they are just the shims used to set the clearence.
They are only a few bucks each, and will need to be changed with the new cams anyway.
Just a pain in the ass to do.
Need to measure current clearence on all cam lobes, remove cams and shims, measure the thickness of the shims and order thicker or thinner shims to get the clearence you need.
https://www.sau.com.au/forums/topic/379457-valvetrain-talk/#findComment-6051203
Correct term is 'under bucket shim' (and there is 'over bucket shim' & 'solid bucket')
Rb26 clearances - 0.018" ( +/- 0.001") intake & 0.015" exhaust ( +/- 0.001")
Measure with feeler gauges when the cam lobes base circle is above the bucket
Face valve/ cut seat/ order thicker shims to close the gaps
Machine tip of valve/ shim to open
Too loose it will rattle and cause premature wear
too tight it will stay open causing loss of compression
I've had to machine a 26 head out for poncams a couple times
https://www.sau.com.au/forums/topic/379457-valvetrain-talk/#findComment-6051252
They are the factory settings
the exhaust usually has a bigger clearance as it expands more during thermal expansion,
but with the rb26 exhaust valves being sodium filled, the sodium absorbs more heat, which stops the exhaust valve expanding, and allows for a smaller clearance
https://www.sau.com.au/forums/topic/379457-valvetrain-talk/#findComment-6051737
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
