Hi every1, Ive recently bought a 34 gtt as my daily until i find my gtr.
I have noticed that under any load, 5th gear is starting to get resistance while trying to put it in.
It is okay when driving around town, but when on freeway its obvious. Doesnt happen when shifting down, only up in to 5th.
Had a similar issue with my 350z and had to get the box rebuilt and a new synchro put in to fix it (cost me $1500).
But my 350z would crunch hard, this doesnt. There is a slight noise but still slots in pretty easily.
Im assuming the synchro for 5th is on the way out, any1 have any suggestions where is the best place to take it and a idea on cost? I live in Rouse Hill in Sydney.
Still deciding whether to fix it or just try and live with it until it completely breaks.
Thanx in advance.
Rouse Hill? Call Unigroup Engineering, talk to Yavuz, tell him you need redline shockproof put though your gearbox for you and book it in. Mention that the club sent you and the price will be good.
Problem solved
Hello Sean, thanx for the reply. I believe the previous owner already changed the gearbox oil (not sure what was put in though) and problem still remains.
Dont know if its of relevance but car is putting out 250rwkw and has a Exedy heavy duty clutch with plenty of meat on it.
Edited by iwanta34gtr
Problem solved
Thanx for the tip. I will call them on Monday morning.
I was researching the fault and found reference to redline shockproof in this thread - http://www.skylinesa...chros-5th-gear/
I also see the seller of the car made a post in there back in 2008 so looks like this faults been present on the car for a few years.
Are we sure that shockproof will make a difference? All other gears are fine. Its just 5th.
Thank u again i really appreciate ur help.
I haven't stripped a 25 box for a while but I think you can get rev and 5th off without pressing everything out of the centre plate.
From memory the genuine Nissan parts are not cheap it will probably cost between $400-$600 just in syncros, bearings, seals and oil etc. Just to do a quick repair.
Don't take this as gospel but it might be work asking the question if it can be done, good luck.
Its the common fix for crunchy boxes, well not a fix, more of a band aid. It costs a lot less than buying all the parts and fixing the box internals so most owners will put the oil in (nickname is smurf blood due to the colour) and live happily with it
Fantastic Steve, thanx again for the info.
I asked the seller and have gone through some service receipts. The box currently has Royal Purple synchromax in it.
Is this good quality? Or is it still worth changing to the shockproof stuff?
Royal Purple is good stuff.. its quite pricey too, if you can live with it till your next gearbox oil change do it then otherwise you can spend the $100 and try the smurfs blood to see if it makes it any better..
Thank u, I called Uni group today.
Yavuz isnt there for a few days but I spoke with one of the guys and he said he is not sure if the Redline will make a difference. And its $120 per litre and will need approx 2 litres of it + will cost $50 to put it in.
Might just live with it for now, until it gets worse.
Hello fatz, Thanx for the info.
Looking at the oil thats in it, the receipt says its 2.5 years old now.
And ive noticed that it only happens around 15 mins or more in to driving. When its cold it doesnt seem to do it.
And I have been doing gentle shifts, it still resists very slightly but no massive crunches.
Thinking about giving the shockproof a go because im thinking when oil gets warm, it thins out. Maybe this is why it doesnt happen when its cold?
Hi there, Is it weird that it only affects 5th?
Ive seen JustJap have a whole gallon of shockproof for $99. I might just grab some and do it myself.
I'd risk $100 and try it out and maybe get no result - just 2 feed curiousity really. But i cant afford to risk the $300 it would cost to take it 2 a shop to have done.
No it is very common to have 5th and rev play up first on many boxes as it is the furtest from the centre plate.
There are a few online stores you can get the redline oil from cheap per quart.
Hi, I am going to get some redline shockproof.
Noticed that there are 2 types - lightweight and heavy. Whats the difference?
Which one should I get for my car / problem and how many litres / quartz would I need? Thanx heaps.
Thanks for the clarification David. I was going to go with the heavy as it states its for problematic gear boxes and mine gives the slight crunch and resistance.
http://www.redlineoil.com/product.aspx?pid=44&pcid=8
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
