Well it's come time to sell my Stagea
Its a june 2000 Build C34 Nissan Stagea, 93,000km and still has a couple of years left on its warranty
It has the Full Dayz bodykit including the carbon insert in the front bar, carbon mirror covers, carbon "d" pillar covers and taillight covers
Engine is still the standard RB25DET Neo, running standard boost control and just a Blitz pod filter
It has a 3" bellmouth Dump pipe, 100cell Stainless highflow cat and a full 3" system finishing in twin 3.5" tips
Auto trans has been fitted with a shift improver kit by MV autos and had a full service and attesa bleed
The tiptronic shift on the MOMO steering wheel is awesome
Rolling on 18 x 9.5 +20 Enkei rims with brand new tyres, Whitlen adjustable rear sway bar and R33 GTR dampner adjustable front shocks
Fitted with a 1250kg towbar it bulls my boat with ease. Great family car, fun car thats practical but still surprises some at the lights
$15,499 ono
I can remove items to make it cheaper, I still have all the standard parts in the shed (ie rims, sway bar, quiet exhaust, compliance cat, shocks,etc)
Pm me for further info
https://www.sau.com.au/forums/topic/379516-sa-c34-dayz-stagea/
Yep, it's time to trade up. To a V8 again.
I need a good tow car for interstate runs.
Something that can tow a car trailer with ease, ie silverado or an older chev truck.
I would have said it would be a trade-down but hey you justify it any way you see fit.
Enough of the chit-chat: This is a very nice car thats has to be seen to be appreciated, whoever buys it better take it on our cruises so I can continue to admire it
Thanks buddy, it will def be a downgrade, but it's what I need so it'll have to do.
Forgot to mention it has dual electric sunroofs, climate control, cargo net and cargo blind.
car Has been serviced every 5000km since i have had it, new fuel filter and iridium plugs went in the first week i got it at 56,000km
  • 6 years later...
It's been a while and I doubt many people are still around but I figured why not to stop in & say hello as I'm the new owner of this Stagea. I loved finding these threads when I was looking at buying the car so I'm glad to be the one taking care of it now. :3_grin:
  • Like 2
Good to see this old girl still alive and well.
I imported it from japan a long time ago now
I hate to be the one to say but it actually threw up an engine light on the drive home & has potentially blown the bottom end so it has been sitting in my garage in pieces for the last 6 weeks.. I'm beyond devastated but I have every intentions on getting a fresh 25/30 & manual conversion dropped in when I have the funds.
It needs a bit of cleaning up since you had to let it go unfortunately but it's still a beautiful car regardless, I can't wait to get her back on the road & looking fresh again.
Cheers for the reply though, didn't think anybody would get back to me :5_smiley:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
