Gday all,
Signed up to the forums a couple of days ago but have been trolling the stagea discussion thread for over a month now and have just bought a series 2 RS4 dayz.
It's great to see a car that's still (relatively) rare on the road but with SO much information and support from enthusiasts. My background is an auto electrical trade (which i pulled the pin on after 5 years a couple of years ago) so i'm hoping to contribute as best I can to the forum. Also if anyone needs some clarification with SA road laws and motor vehicle regulations I will also help as best as I can.
I'm still a noob when it comes to Stageas but the discussion pretty much covers everything so i cant see my self not being bale to find information when I need it!. It was a big step for a Toyota enthusiast driving a JZX100/1JZ to cross over to the Nissan/RB scene but I couldn't be happier with my new set of wheels!
https://www.sau.com.au/forums/topic/379527-the-silver-clysedale/
Z32 lol...Engine out
But yeah, Its a 2 stage process to get the filter out of the Snoarer, unscrew from top, place down on X-member get underneath, place new filter on X-member, and try and thread it blind from the top
Haven't done my first service on the stagea yet but I can just imagine what the boffins at toyota were thinking when they decided on the location for the filter...
..."hmmm lets put it where only small children might be able to access it, lets make it so some how it tightens itself tenfold so that you can barely get it off and lets put it right here so it pisses out oil all over the engine mount when ever you do a service!"
so true mang, so true.
You haven't worked on a 1g-fe, now that has a hard oil filter to change. :P
RB is a walk in the park.
To the OP - Welcome aboard
Landrover TD5 Diesel
Not the centrifugal filter, the screw on Z614
/discussion
i'm sure there are some other bad ones, but the skyline isn't that bad. the fwd sr20 (at least in the n15 pulsar) is pretty bad. you can see the filter, just can't get to it without having to have your wrist at 90 degrees, while also having it up against the head. the filter on the 2000 model corollas is also a bit of a pain. it's right next to the exhaust.
best i've seen was the 3.5L v6 in the magna. it basically has a factory relocation kit. you look under the car and there it is, hanging down with nothing around it. you can get both hands on it. not contortionism, no burnt or scratched hands. no tipping oil all over the place trying to negotiate it out.
a
2008 corolla is good. Filter is directly above the sump plug and on a right angle, so absolutely no mess to clean up when you remove it or drain the oil.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
