looking at building a strong RB chasing revs not over all power or response
what path do people think i should go down
parts/motors i got
rb25de neo x1
rb25det x3
rb20det suit rebuild x2
turbo t67 10cm hight mont
nistune and all the bolt ons
full work shop with equipment with ok mechanical experience, hands on yes theory no haha
help be appreciated thanks matt
  • Replies 45
I'm guessing cause it sounds cool.
Rb 20 crank in 25 block with gtr or stronger rods and custom forgies would rev hard and hold together.
Makes the gears abit longer and i love limeter
Normal 300kw 25 is getting abit boring
Thinking of working neo24 for its soild head with 20 crank and rods, low comp, porting
Not sure what cams valve springs to use or type hmmm
Ye there is some serious investment that needs to go into the head.
Just a set of springs really isn't going to cut it for extended 9000rpm+
sounds good. some 290 degree cams maybe?
Well 290 degree cams give you 1000rpm response over any other choice according to some around here, so they should be the first items purchased!
espesially is they have JUN or HKS stamped on them..
No other 290deg cams will do it though
Hahaha.... But seriously you want revs and you don't care about power or response... Buy a Honda with vtec yo, or for even more fun, go an give yourself a tax audit.
You'd be mad to put in anything less than 320 degree
Or use the money you will need to spend on it rev to 9k for any extended period without lunching itself on 5 stock motors with boltons like most skidders do.
Lunch a motor, swap in a new one, simple.
Do that.
The most insane RB track car I've ever heard, as well as a large amount of guys from the drifting in melbourne was powered by a stock RB25.
Of course if it had 290 degree cams and a smaller stroke crank with custom rods and pistons it would've been better
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
