  • Replies 45
yer my 32 with 25 would happily rev at 7800 at 270kw with my 4kg aloy fly wheel with the same turbo set up as simon-r32
the t67 on a 20 might not be to good haha but i have been thinking about it
Ifraz (sp) makes 640hp at the wheels with his RB20. Pretty sure it has standard rods and yes RB20's will do 9k every day. Even with standard rods mine didn't fail until the oil pump finally let go. It saw 9k rpm most of the day for 18 months. Put in some rod bolts and it will survive.
If you want to rev to 10k + I would get a forged crank for a 26 and do up the Neo engine with a 2.8 stroker. 290 - 310 degree x 10.5mm lift cams and all the supertech gear in the head.
It will swallow babies but it will sound like an FA-18 on take off.
iv pulled down a few 20s and 25s its seems to be no proplem to install a 20 crank and rods in a 25 block
so a shorter stroke and a comp ratio of around 7:1, but i could get the block decked to bring pistons back to level
My only advice would be to wear protection.
If you are going to hang your dick out the window, which it sounds like that is all you want to do, don't be upset when the guy with the better setup passes you sideways
LOL best post this year.
The most insane RB track car I've ever heard, as well as a large amount of guys from the drifting in melbourne was powered by a stock RB25.
Of course if it had 290 degree cams and a smaller stroke crank with custom rods and pistons it would've been better
Panik hands down for me, best sounding RB I have ever heard :)
Sounds similar to the car Steve speaking about. Not sure which i prefer, hard to get the exact from video but having seen the other car in person it was certainly the winner. Best I've heard in 10 years!
Stock 25 head, 3ltr, 6boost manifold with a gtx35. Not sure of the gate/exhaust combo etc.
Sound is as much to do with the manifold, exhaust, gate size, angle/length of screamer as it is RPM anyway.
You could rev to 9000rpm and it could sound shithouse.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
