hey guys.
had a change of heart in what im doing with my car, so a few bits and pieces have to go.
1. R32 4 door roll cage. 6 point, full cage just no cross bar, perfect for street car and can still take passengers! also the rear braces the follow down to the wheel arch follow the pillar line and pretty much hidden with stock trims. tucks in nice and tight behind the rear seats too. possibly chromolly, not sure but its super light weight!
asking $800ono
2. genuine R34 drivers side seat rail to suit fixed or recliner seat. going for a lower rail.
owes me $150 ono!
3. Genuine 38mm TRUST external gate. not sure what spring is in it. came off car in good working order. Its 4 bolt flange, but smaller style. comes with a flange to suit!
$200
have a heap of stock parts for dirt cheap to suit RB20 and RB25 just ask!
pics will be up later tonight or can mms straight to your phone.
located in western suburbs.
prefer if you call or txt me rather then pm. on 0401421074
cheers, Brock
https://www.sau.com.au/forums/topic/380010-r32-4-door-cage-legit-as/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
