Does anyone know somewhere that makes seat rails?
Would the BRIDE ones fit on a Sparco Evo 2 seat?
Also the seat needs to be kept low, the stock seat rails are really really low. So it would be good to keep it that way!
Let's talk the same language here.
The seat itself sits on a rail that slides back and forth.
This rail then bolts onto a frame that has eyes for the bolts that go into your floor.
The rails are general easily available in reasonably generic form (ie. from say Revolution Racegear).
The frame that is custom to the R32/33/34 (same IIRC) is harder to get.
T.
me and a mate made some, still need some finishing though but are pretty good! totally fixed dont slide, but who needs that if setup right in the beginning. they are illegal anyway unless the fold forward! just used 0.8mm flat bar and welded it up! can post pics if you need ideas!
Sparco have something like rails for something like 1,000 different model cars. I contacted an American website regarding the Evo 2 who said "Their are no left-hand drive Sparco seat rails for R33's available, only right-hand drive" (He must have thought I was an American).
Does the Evo2 have sidemounts as well as floor mounts or just floor mounts? I can't actually remember....
Try calling the Australian Sparco Distributor (??).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
